What does it mean when someone says these are 4 ohm speakers and my receiver can only take 6? will they not work with the receiver?
Electromagnetic devices have a so called impedance measured in Ohms (Resistance is also measured in Ohms). When you connect two electromagnetic devices they must in some way match. To put it in the simplest terms, the output impedance of one must be equal to the input impedance of the other. The better the matching the better the coupling.
Coupling may not be optimal but they should work.
SOURCE: speakers
You should have no problem with 8 ohm speaker with this unit as you would with the 6 ohm speakers. The 6 ohm requirement is only not to go under that value. The only consequence of hooking up higher impedance speakers(8 ohm) to this system is that you will have slightly lower volume than with lower impedance speakers(6 ohm).
SOURCE: tweeter does not work in surround speakers
If you are trying to find out if tweeters are ok, place them to the mids
and listen. if good, then trouble lies in the individual amplifier inside ur set.
Good Luck
SOURCE: can I run 8 ohm speakers when the speaker jacks
No problem, you will have just halved the power output. Will not be as loud as previous.
SOURCE: CAN I REPLACE MY 2.7 OHM SUBWOOFER WITH A 4 OHM SUBWOOFER ON MY S
No Harm will be done if you do this,compleatly 100 precent safe.
SOURCE: what is the impedance of the JAMO A3SUB.3 speaker?
22K is the impedance listed in the specs but you may have to look on the actual speaker itself to get the impedance of the physical speaker.
