Home | Alpine | CDA-W550 | Aux or line in
Alpine CDA-W550
Problem for Alpine CDA-W550
Aux or line in
By mickeyr on Sep 27, 2007
Can you tell me if the CDA-W550 has a line in or aux in jack? If so where it might be located on the unit. I'm considering satellite radio install.
Comments:
Oct 02, 2007
- Thanks for the feedback. Uncertain as to my approach with the hook-up. I wonder if the improvement associated with direct connect vs. RF warrants the purchase of a new reciever with aux inputs??
Same Problem
Jan 30, 2009
-   how to turn on the aux -   Guest
Best Solution
posted on Sep 29, 2007
Helpful)
mixmaster
Rank: Guru
Rating: 90%, 1605 votes
No line in or aux inputs.
Installation Manual is here;
http://vault.alpine-usa.com/products/doc...
Best of Luck.
Was this helpful?
Yes
No
Solution #2
posted on Oct 09, 2007
Not Rated)
conkers209
Rank: Apprentice
Rating: 0%, 0 votes
I have the same unit and yes, you can put a AUX cable to it, goto best buy or a similar place and get the AI connection cable plug to RCA and then get a RCA to headphone jack so you can plug a ipod or any other MP3 Player to the unit. But the catch to this is that you will also need to pick up a switch and install it somewhere near the head unit because you will need to ground the pink (I believe it's pink) wire somewhere in the car where there is metal. You need the switch because when you ground it, that causes the unit to goto auxiliary mode and you will see the word auxiliary on the display. And after everything is connected correctly, it should work. And before I did this on my car, I did call up Alpine and all the info I typed is what they told me. Don't bother figuring out how to put a "True" ipod connection because you can't, but what I did was use the aux connection and got a ipod holder and mount and mounted the holder next to the head unit so I am able to control the ipod easily. And the sound quality is as good as anything that comes out of my ipod so if the SAT receiver has a headphone jack, I'm guessing it does, then use the same method and use the sat receiver instead of a ipod or zune or whatever you use. But you need a switch so you can go back and use the cd player, tape deck and AM/FM radio. That AI port on the back of the alpine is made to add a cd changer but they sell connections to RCA, so make sure you are getting the right one because Alpine has two kinds of connections, the one you want is the older version, it's a rounded connection.
Was this helpful?
Yes
No
Popular Solutions for Alpine CDA-W550
Questions and Unsolved Problems for Alpine CDA-W550
Do you recommend Alpine CDA-W550?
Answer
Answer
i did the AS button and the 1234 code but now i'm on 7 safe and it won't move. I've just been given... (More)
Answer
Which colour wire on the 7190ET unit is the backup power wire ?
Answer
frozen screen after about a song or 2 listening to the ipod. i have to unplug it and plug it back in... (More)
Answer
how to hook up a kdc-mp438u to a 95 grand am
Answer
how do I turn on the AUX function on the Alpine CDA W550
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Alpine CDA-W550:
Top In Dash Receiver Experts
Rank: Guru Guru
Solutions: 14110
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more In Dash Receiver Experts
Top Audio & Video Equ... Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
