There is a way to put the crown back in by pushing a certain bar in the watch, but you need to take it to a pro because watch insides are super delicate. I've changed batteries, removed links etcc for 16 years and I wouldn't touch this procedure
<span style="font-weight: bold;">Time Setting for Models Without Calendar</span><br /><span style="font-style: italic;">Note: When setting the minute hand of a quartz watch, advance it a few minutes ahead of the time and then turn it back to the exact time.</span><br />
<ol>
<li>Pull out the crown all the way. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li>
<li>Adjust the time by turning the crown in the desired direction.</li>
<li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands,
push the crown back in to the normal position in accordance with a time
signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Time/Calendar Setting for Models With Calendar</span><br /><span style="font-style: italic;">Note: The date will change gradually between 9:00 PM and 4:00 AM. For some models, however, it will change instantly when the hands pass the 12 o'clock marker at midnight.</span><br />
<ul style="font-weight: bold;">
<li>For models with date calendar</li></ul>
<ol>
<li>Pull out the crown to the first click.</li>
<li>Turn the crown until the previous day's date appears in the calendar frame.</li>
<li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li>
<li>Push the crown back in to the normal position.<span style="font-style: italic;"> Note: If your watch has three hands, push the crown back in to the normal position in accordance with a time signal for "00" seconds.</span></li></ol>
<li>For models with day and date calendar</li></ul>
<ol>
<li>Turn the crown in the opposite direction until the desired language (bilingual) for the day before the desired day appears in the calendar frame. <span style="font-style: italic;">Note: For Cal. 7009 and 7019, push the crown back in to the normal position and then push it repeatedly to set the day.</span><br /></li>
<li>Pull out the crown to the second click, and advance the hour and minute hands until the desired date and day appears. <span style="font-style: italic;">Note: If your watch has three hands, pull out the crown when the second hand is pointing to 12 o'clock.</span></li>
normal position in accordance with a time signal for "00" seconds.</span></li></ol><span style="font-weight: bold;">Note:</span> Do not change the calendar between 9:00 PM and 4:00 AM as it may not change properly. If it is necessary to set the calendar during that time period, first change the time to any time outside those hours, set the calendar and then reset the correct time. When the day shifts automatically to the next day, the other language will temporarily appear.<br /><br /><span style="font-weight: bold;">Note:</span> When setting the hour hand, check that AM/PM is correctly set. The watch is designed so that the calendar changes once in 24 hours.<br /><span style="font-style: italic;">Turn the hands past the 12 o'clock marker to determine whether the time is set for the AM or PM period. If the calendar changes, the time is set for the AM period. If it does not change, the time is set for the PM period.</span><br />
I presume you're referring to a chronometer watch?
You need to twist the crown (little screw on the right side of the piece) counter clockwise until it slightly pops out. This is position 1. You need to pull the crown outward gently until you feel a lug sensation. This is position 2. Turn the crown to adjust the 'date' until you reach yesterday's date (one date before what you actually want). Then pull the crown outward again feeling that lug sensation. This is position 3. Turn the crown so the minute-hand swings in the normal movement of time (don't swing it backwards). Keep doing this until the 'date' turns to the current date. Now your piece is set on the correct date and the minute-hand is in the "a.m." Now keep turning the crown until you've reach the current time (noting the am/pm period you want). Push the crown inward to Position 2, then to Position 1. Turn the crown while in Position 1 to wind the spring. How many times depends on your brand, mine is 35-40 turns. Once I am done, push in the crown and turn simultaneously to lock it down. It will stop when it is seated properly.
You can adjust the analogue hands without changing the digital ONLY when you have set the watch to 24hr fornat. Do this by going to the second Timezone screen (T2) and pressing the crown once briefly. If A or P appears, the time display is in 12-hour mode. If no letter appears, the time display is in 24-hour mode. To change mode, press crown briefly a second time.
Now go to the basic display where no digital info is shown. Pull the crown out. Now slow turning will adjust the minutes and fast turning the hours, but only of the hands. Therefore you can synchronize the two. After they show the same time, press the crown back in and adjust both times together using the crown as normal on the standard "Time" digital screen
Unscrew the crown (the main knob on the center right side of the watch casing), wait until the second hand is at the 12 o'clock position, and pull the crown knob up so that it clicks once.
Press the button below the crown knob repeatedly until the hands of the alarm dial point to the time within the next 12 hours that you want the alarm to ring. Pressing the button once will move the alarm one minute forward. Pressing and holding the button will move the alarm forward quickly.
Pull the crown knob one click further out and turn to adjust the main hands to the correct time, to take into account the time you took to set the alarm.
Push the crown knob two clicks back into its normal position, and screw it into place until it locks.
pul crown all they way out
press top right button to set the minute hand
& bottom right button to set the hour
if not work then puch back crown to 1st click and do it same function ,, if still not working then pull crown again and push and hold both button for 5 sec. its reset ,, and try to adjust it again by pressing top & bottom button
hope that will help if not and you are in chicago
bring it to us
at
Amfix Jewelry & Watch Repair
203 N. LaSalle St
Chicago, IL 60601
312 641 7000
go to Buliva web site and look for the chorograph 561/598
FEATURES
1. Hours, minutes, seconds and date display.
2. 60 minute Chronograph (CHRONO) with minutes and
seconds display.
3. 24 hour hand, permanently synchronized with the normal
12 hour hand.
A. SETTING THE TIME
1. Pull the crown out to position “3” (See diagram). If the crown has
a “screw-down” lock, then unscrew the crown lock first by turning
the crown toward you, then pull it to position “3”. Do not forget to
screw the crown back “IN” after all setting is completed.
2. Turn the crown towards you (hands moves clockwise) until the
date changes at approximately midnight.
3. Continue turning the hour and minute hands to the correct time.
If it is afternoon you must go past 12 o’clock again (noon) to set
the correct time.
4. When the correct time is set,push crown back to position “1”.
B. SETTING THE DATE
1. Pull crown to position “2”(See proceeding diagram).The watch
will continue to run.
2. Turn the crown away from you until the correct date appears.
3. Once the date is set, push the crown back to position “1”.
Note: Do NOT set the date between the hours of 8:00 PM and
3:00 AM.This would not damage the watch,but the date may need
to be reset later.
C. CHRONOGRAPH (CHRONO) ADJUSTMENT
If the chrongraph second hand is not positioned at the proper
starting position (12 o’clock or “zero” position), use the below
procedure.It does not need to be repeated unless the watch
receives an impact sufficient to move the hand out of position, or
the Battery has been changed.
1. Pull crown out to position “3”.
2. Push button “A” to move the Chrono Second hand (long hand) to
the “0” or 12 o’clock position. Each button push will move the
hand one step – BUT holding the button down will advance the
hand rapidly.
3. Push crown back to position “1”.
D. USING THE CHRONOGRAPH (CHRONO)
Note: The maximum chrono reading is 60 minutes, However the
chrono will continue running once 60 minutes has passed. The
resulting one hour periods may be added together mentally to keep
track of longer periods.
For example – If you know that approximately one hour has
passed since you started the chronograph, and the chrono reads
25 minutes, then you know that the chrono has been running 60
minutes plus 25 minutes, which is one hour and 25 minutes.
1. Push Button “A” to start the chronograph. Push button “A” again
to stop the chronograph.
2. Push button “B” to return the two chronograph hands to the
“Zero” or starting point.
3. The Chronograph can be stopped and started again
(Button “A”), repeatedly, to “ADD” times together.
BOOK NO. 561/598 Chrono FS00/01/10 BOOK NO. 561/598 Chrono FS00/01/10
Watch Setting Guide
4/2007
Unfortunately your watch do not have reverse action, so, you have to go all the way forwards till you reach designated time again. One more way how to set the right time is to disconnect the battery and wait till the real time reaches the hands of your watch, then put battery back and set again. If watch has a STOP function (crown pulled out), then you don't have to disconnect the battery- just pull out crown and wait. By the way: pushing the button in accelerates minute hand constantly, but if you'll push the button rapidly, it will move mimnute hand bit by bit. Use this feature to set desired time more precisely. Do not forget to rate, please.
I did find two authorized dealers: www.kenmarwatches.com www.princetownwatches.com Contact both and request users manual fur your specific model. They must be able to help.
Tags have a screw down crown (winder knob) turn the knob counter clock-wise until you feel the crown unscrew (not off) then pull the crown carfully. It will pop once this is for date adjust. Then pull once more and you can now adjust the hands, set accordingly then push crown back in. After you push it back in gently compress the crown and tighten clockwise until it stops. CAUTION!!!!!!! Tags are not waterproof if the crown is not screwed back down. I hope this helps I am actually a car guy (just happen to own a couple)
