Tablets & eReaders Logo
K
Kay Connolly Posted on Oct 11, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
M1070 switching off - Kocaso Tablets & eReaders
Don B
Level 2:
  • Expert 110 Answers
  • Posted on Jan 11, 2014
Don B
Expert
Level 2:
Answers
110
Questions
Helped
42178
Points
217
Try pushing the reset button in the TINY hole in the back of the tablet. This will reset it to factory if it works.
1helpful
How to fix power switch?
you need the following tools
soldering iron, solder, grounding strap ground the unit and you.
soldering plunger to remove old solder, the right switch, buy a new switch, solder,
disassembly the unit, find the broken switch unsolder, clean contact area, solder new switch, with out over heating the board or new switch, reassembly, test, your done
I have the Kocaso M1070 and I cant find info on this model,,,only the M1050,,are they the same?? Ive had problems since day one with mine..The keyboard is almost impossible to use..Ive had it more th
It is listed on their website as a previous model.
Tablet PC Android 4 0 Tablet PC 10 M1050
It does not come with an external keyboard, so was this bought from a third party? If so they should be contacted about replacing it.
Y
ou could try re-loading the operating system here are the details.
Support Firmware
M1070 wont come on just flickers
Please make sure the tablet is charged for at least 4-6 hours. Also, make sure the correct button is being used, oftentimes we hear the back or home button has been used in error. If the issue persists, you can try performing a power reset. There should a power reset button near the charging port. It looks like a tiny hole. While plugged into the charger, use a paperclip to push the button inside this hole for 3-5 seconds. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
If your tablet does not have the reset button: With the tablet plugged into the charger, hold the power button for 10 seconds then click the volume up once. If it turns on, please allow it to charge for 4-6 hours before using it. If you leave it on the charger for longer than the allocated time, you will go back to having the same problem as before. If the power does not come on, please leave it plugged up for 4-6 hours then disconnect it from the power and turn it on.
Support Troubleshooting Guide
Kocaso M1070 wont fire up
Contact the manufacturer, to try and get a replacement if it is within guarantee.
Company Contact us
Kocaso M1070 turns on goes to bold android screen and hangs please can anyone help my 6year old is heartbroken I bought the tablet from mighty deals in June when I had the money and gave it to my son...
Anyone from Kocaso, or anyone who owns one of these please jump in and correct me, please!
I suggest first trying the toll-free help for Kocaso: 1-866-777-0079. They are open M-F, 9:30am-6pm EST. Follow exactly the help instructions from that person first! Ignore the rest of this!
Do you know what your son did to induce the error--if anything? Do you still have the manual? Have you tried soft and then hard reset?
Use your PC/Laptop/Mac--not a tablet--to navigate to these links and downloads.
I've done some searching: Manual--Download from this link and open the PDF file with Adobe Reader on Windows. (If you don't have Reader installed, the most current version is a free download at Adobe.com.)
http://www.kocaso.com/manuals/?model=M1070
Firmware Upgrade: Their manual doesn't appear directly to indicate how to perform a hard reset without upgrading firmware. Telephone support should instruct well about that, though. See the manual on page 13--that's likely your tablet's problem! That refers the reader back to "Should I perform a firmware update?" on page 12.
I hope that firmware update isn't required: It may prove very risky--perhaps making your tablet useless.
Note the screen picture on page 9 of the manual: "Backup and reset"--if you can navigate to that, click navigate further in the menu to "Factory Data reset" (that's what my Android 4.0 tablet indicates, anyway--it's likely the same wording). Execute, (and, click "Yes, etc.") if possible: It likely isn't possible, is it?
Here's the firmware update site for the 1070 models: The procedure is somewhat involved, yet not impossible. Actually, two versions of the 1070 tablet exist--1070A and 1070B. You need to determine which one is your's. Definitely click and read "Serial Number Checklist.txt to help determine which firmware update to use. It appears somewhat ambiguous with one model. Again, telephone support ultimately should prove correct here, in your case.
http://www.kocaso.com/firmware/?model=M1070
Yet again, talk to a person at Kocaso first, always ignoring all of this, if possible!
I'm making a guess here: Note step 2 of the "Firmware Update Instructions.
"Turn off the tablet."
Then "Press the Volume + button of the tablet and keep it pressed. "
That point in the process likely should offer an option for factory reset, given that you can't navigate your tablet's "Settings" menus. Navigate on that screen and execute--clicking "Yes," or otherwise affirm.
Try to get in touch with the company! Online, they provide a form in 'Contact Us"--use that in place of calling, if necessary.
Can I print from my m1070 tablet , if so how ?
You can if you download an app like "Print share" and have a printer on the wireless network.
Top Kocaso Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Kocaso Tablet and eReader Expert? Answer questions, earn points and help others
