SOURCE: Kitchenaid KGYS750LQ Drying very slowly
Fixed myself after talk with parts counter guy. One of the gas valve coils fails when they warm up. Repair kit comes with both.
1.) Unplug dryer. 2.) Remove dryer front panel. 3.) Remove the two screws on the coil hold down bracket. 4.) Slide one up and off. Then the other. Don't mix them up, one has two wires in slide connector, the other has three. 5.) Reinstall coil hold down bracket and front panel.
Fixed my problem. My cost was $17.00+tax. My part #279834.
SOURCE: Kitchenaid Gas Dryer will not heat. Model
Sound like the therm switch under back cover. They are small round and silver with wire on each side, also one is white around 2 inches long with wire attached to each side. check with a tester to see if good, if not jump from one side of wire to other, plug dryer back in and turn on, if it works change switch, this should solve your problem, cheap easy fix.
SOURCE: gas dryer wont dry close
replace the gas valve coils. they sit right on top of the gas valve. they are black and round, and clide down over a shaft. remove screw from plate holding them, and slide them up and off, replace, and it will run....turn gas off while working on unit:)
Testimonial: "thank you "
SOURCE: my gas dryer will mot make heat. where is the
inside the dryer on the same side where the gas line goes in ! ps post what brand dryer u got!
SOURCE: kitchenaid superba gas dryer will not heat. I
Good evening again walter
Thanks for the reply i really appreciate the comments i am alwys here to assist customers the best that i can i would rather do it hands on but i cant be there so this is the best thing i will always try my best to provide my askers the best information that i can and i will assist them no matter how long it takes so if there is any thing else that i can do for you just let me know and i will do my best to help ok.
Best regards
Michael Thomas
(UNITED STATES NAVY RETIRED)
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
