2002 Lexus LS 430 Logo
Posted on Apr 20, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Lexus battery is there a specific replacement battery recommended for the ls 430 2002 model?
  • 1 more comment
  • jfups Apr 20, 2009
    can i get a replacement at costco or sams that will work just fine without damaging car?
    sorry, what is the battery application catalog?
  • Marvin
    Marvin May 11, 2010
    of course there is.
Marvin
Level 3:
Top Expert:
  • Lexus Master 85,242 Answers
  • Posted on Apr 20, 2009
Marvin
Lexus Master
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29060957
Points
266281
JUST USE THERE BATTERY APPLICATION CATALOG TO SELECT THE CORRECT SIZE FOR YOUR LEXUS, U DON'T HAVE TO USE THE MORE EXPENSIVE FACTORY BATTERY, IN MOST CASES IT IS A WASTE OF MONEY.
I have '91 lexus 400 im only getting a clicking
More than likely the battery needs to be charged or replaced. If the battery is over five years old this is a strong possibility that it is bad. AAA will come to your location and test your battery, and charging system for free, if you are a member. They will also replace the battery at your location at a costs. I recommend that you become a member of AAA, as one towing, or service call more than pays for the annual membership fee.
Wanting to buy a 1998 lexus ls 400 after replacing the battery the dash lights up but the engine won't turn.. What could be the problem
Are there any warning lights on in the dash, may a security warning light? If so you will need to reset the security system, refer to the owners manual or callthe local Lexus dealer for instructions.
1helpful
2003 Lexus ls radio won't come on after battery
The radio anti-theft has locked itself out. You need to go to your local agent with ID and they will check your radio serial number and be able to give you the correct unlock code. (Make a note of this for future ocassions).
1helpful
2005 LS 430 does it have a timing chain or belt?
Timing belt...Lexus recommends replacing at 90K.
2helpful
2answers
Step by step instructions to change starter/94 Lexus LS400
Disconnect the battery.
Disconnect the wires from the starter.
Unbolt & remove the starter.
Bolt the new starter into place.
Connect the wires to the starter.
Connect the battery cables.
2answers
My battery seems to be very low in my key for my 1998 lexus ls 400. Can I replace the battery myself or is it tricky?
Usually not. Disconnect negative battery terminal, then positive. Next remove battery hold down (type is specific to car model). Battery then lifts out and replace with correct new one. Install is reverse.
Battery went dead, we replaced the battery but now the electronic parts dont work.
this sounds silly but you may be able to reset by removing the dome lite fuse and reinstalling, Lexus seems to use that circuit on some early models
6 year old battery
always put the black (ground) on first and disconnect it last.
Top Lexus Experts
ROBERT GARCIA
ROBERT GARCIA
ZJ Limited
ZJ Limited
Are you a Lexus Expert? Answer questions, earn points and help others
