Bosch AHS 45-16 Electric Hedge Trimmer Logo
frank hall Posted on Sep 27, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Cut through cable on AHS 45-16 how do iget trimmer apart removed all screws apart from one which is different to res but can't see what it is
Andy Nolan
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 08, 2014
Andy Nolan
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1437
Points
So how do you replace the cable?
Dave
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Oct 19, 2013
Dave
Expert
Level 2:
New Friend:
Answers
101
Questions
0
Helped
46435
Points
147
They have security screws on them to stop unauthorised tampering
I cut the cable of my Bosch AHS 70-34 hedge trimmer.I have rewired it but it wont work,Alan
You must make sure you wired it properly and the connections are good
What is the best way to sharpen bosch AHS 45 16 HEDGE TRIMMER
Please understand, if you do, you may well start a business!
You will have to take it all apart, and then take either a file or a grind stone and resurface the blades.
I know you can learn this skill, if you do not know how, but this time it will take you to do it right will be hours, and if you charge a reasonable rate to do this for others, you may find it cheaper to buy a new one!
You may be able to find a web-site by looking on-line that will tell you exactly you to do this.
God bless your efforts.
Why did my weedeater lost power when trimming on grass but still spun?
There is a cable that runs from the motor to the trimmer head check that. Remove trimmer b.y removing small screw at the base of trimmer head
I have Bosch hedge trimmer AH15 63-16C which has stopped cutting. It still seems to be working as it should and the cutters moving as normal but suddenly stopped cutting? Just wondering if this is fixable...
This sounds similar to a problem I have with my Bosch AHS 60 24s. The blades are moving but not independantly and therefore not in a cutting action. I took it apart and the bottom blade has slipped off the drive wheel. I put it all back as it should be but as soon as I used it again, the same thing happened. I'm not sure why this is happening, it may be that the motor end of the bottom blade has become slightly bent, so I will be trying to straighten at the weekend. The cost of replacement blades is prohibitive and time for a new hedge trimmer. Has anyone else had this problem and a different solution.
I took it apart to clean, and now I barely cuts
Make sure the blades are even. It sometimes is hard to match when you take them apart. If they are even off a little bit they don't work. good luck
1helpful
Hedge trimmer blade not moving
I have a Troy-Bilt gas powered hedge trimmer. My blades would not move. After tearing it apart, I found that there were some spacers under the 5 or 6 screws along the blades. These spacers are steel and designed so that you don't overtighten the screws. However, around those steel spacers, there is a teflon type material that makes the oval shape of the slot. That teflon had fallen apart and lodged so that the blades would not move. I removed the teflon and put the spacers back in and it now works fine. There is a little play between the spacer and the edge of the slot and it will probably eventually wear out but at least I got a few more cuttings off of it.
I tried to clean the blades but now it wont cut and also it sounds tremendously loud
are all the screws tight? Sometimes my screws on my blades come loose and I can't tell until all of a sudden they fall apart in a clients hair
Top Bosch Garden Experts
john h
NOEL
NOEL
ADMIN Andrew
ADMIN Andrew
Are you a Bosch Garden Expert? Answer questions, earn points and help others
