I recently had the battery chnaged in my W2 for the first time and now the main second sweep and the minute sweep are not returning to 12. I wonder if some combination of button presses will reset or if something should have been done when the battery was taken out?
SOURCE: raymond weil tango
hey! to be frank .
its very difficult to analyse and repair the watch .
better to service or repair it
SOURCE: raymond weil watch - broken
Don't quote me but, I think R. Weil has a life time warrenty on their bands. Go to R weil on line and find out. Let me know.
SOURCE: re-set quartz chronograph sweeping second hand
Easy Soultion worked for me. Believe Me I was worried only had the Seiko Sportura for a week now. My second dial for the stopwatch was re-setting to 5 seconds instead of zero. The Solution is
1. pull the Crown all the way out ( In the position you take the crown to set the time , second click ).
2. To set the minute face of stop watch , keep pressing the top button untill it is zero. To set the second needle to zero keep pressing the bottom button untill it reaches zero or where you like it to re-set each time. Depend on you.
3. Once all neddles of stopwatch are at resting postions ( usually zero) secure the crown back to its normal postion. Test your stop watch , hopefully it will go back to zero when you press the reset button. C
Glad to help. [email protected]
SOURCE: watch stopped running when not worn
Make sure you are turning the crown clockwise and stop winding when you feel the tension increase. Also, try wearing it for a day even if it is not runninr; the motion may be enough to get it going if it is an automatic.
There may be something more wrong with your watch.
If the RW is less than 2 years old you should be covered, they have one of the best warranties in the business.
If it needs repair and is older than 2 years, I would still send it to the RW repair center in NY to see what they can do.
