Sony Str-dn1010 Power Transformer Bando Bd31b1-0015 Bem1-ecz Tested And Working Logo
A
Anonymous Posted on Sep 07, 2013
BD21A33A-0007A TRANSFORMER WIRING DIAGRAM - Sony Str-dn1010 Power Transformer Bando Bd31b1-0015 Bem1-ecz Tested And Working
2answers
Looking for circuit diagram for Dixon Power Mixer TMS 8?
This appears to be a South African unit? See if the link works better for you. An electronics technician could fix by component testing and by knowing how to wire a transformer (high voltage windings and low voltage windings).
https://www.google.com/search?q=dixon+power+mixer+tms+8+wiring+diagram
1helpful
?Location and photo of the transformer for a gaffers and sattler wall furnace model S 90 FE.
No. The transformer "transforms" 240 volts to 24. Meaning the high voltage coming into the machine. Normally has a "c",208,240 written on one side. Follow your main power wire into the machine. Branches to heater and transformer. Look at wiring diagram
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Color code for theromstat
Wiring Examples and Instructions
How-To-Wire-It.com
Basic or Common Connection Points
Terminal Colour Signal-Type Description C Black 24 Vac Common Common side of 24 Vac Transformer See Diagram below R or V red 24 Vac Transformer Power Power side of 24 Vac Transformer See diagram below RH or 4 red 24 Vac for heat 24 Vac power before heat switch see diagram below Rc Red 24 Vac for cool 24 Vac power before cool switch see diagram below Y Yellow switched power (cooling) Signal to turn on cooling system see diagram below W White Switched power (heating) Signal to turn on heating system see diagram below G Green Switched power for fan Signal to turn on fan (forced air) see diagram below
Heat Pumps/Multi-Stage Units
Terminal Colour Signal-type Description Y2 Can vary Switched power (2nd stage cooling) 2nd stage cooling signal to compressor W2 Can vary Switched power (2nd stage heating) 2nd stage heating/ sometimes used as emergency heat E Can vary Emergency heat enable Dedicated emergency heat 0 Orange Reversing value Reversing dynamics of the heat pump ----
Wiring a Schumacher Se4020 6 socket transformer wiring.
I would contact them, they may be nice enough to send you one.
Email us:
Product and technical information - [email protected]
Has anyone come up with the wiring diagram for the LET60 120/12 volt transformer
Most all transformers have the diagram already on side of them with how to wire up. Sounds like your actually talking about a ballast, if this is the case the diagram will be wrote directly on the product as well.
I’m happy to help further over the phone at https://www.6ya.com/expert/michael_341f3f9dee622e54
I have a Ruud/Rheem gas furnace. The previous owner jury-rigged the transformer to exclude the heat source. As per the wiring diagram, I've sorted out the wiring from the thermastat to the...
It doesn't make any difference if you only have two wires from the Air Conditioner. I would put red on Y and white on C ..... All the air conditioner needs is a 24 volt Common wire and a 24 volt Power wire to pull the compressor contactor in......
Need wiring diagram for transformer and themostat
http://www.nordyne.com/Literature/7083400.pdf
There is a manual it has a diagram inside. http://www.nordyne.com/Literature/708340b.pdf
That's all the info i could find mentioned at all on the net, I did exhaustive searching....
Low voltage transformers problems
make certain that you connect the right wires into the transformer. there should be a wiring diagram on the transformer, this should tell you where the wires need to go. more info will help.
Wiring diagram for 6125-S freezer prior to 1996 (serial#311387-T)
http://www.delfield.com/docs/uploaded/del/manuals/archive/dm6000.pdf
go to this site. It is your manual for your unit and it has a diagram in it. check it out. The power switch just breaks the power side of the incoming power. The transformer is a/c so it is not polarity sensitive. Usually the transformer will have a black and white wires on one side to indicate the high voltage side.. I have a ladder diagram scanned from the original manual but it is no different that the web site.
Hope this helps.
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
ZJ Limited
ZJ Limited
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
