SOURCE: My 2000 Accent GL is reving into HIGH RPMs! 5 speed 1.5 L
check your anti freeze and watch your temp gauge.any check engine light on.
SOURCE: 95 Mustang gt backfiring and RPM's bouncing
sounds like you have jumped a tooth on the timing if not timing out
SOURCE: have a 1991 buick lesabre 3800 v6, cant get to
Check the ECM if it has the number 1228253 on it, this is what is wrong with it. Gm trashed all of these bad ecms. Get a 16198264 as they do not cause a cutting off problem . Get a delco ecm , aftermarket units will give trouble and may be a rebuilt 1228253 which is junk.
SOURCE: SL2 Won't start; previous codes=PO
I HAVE A 98 SATURN, WON'T EVEN TRY TO START EVERY ONCE IN A WHILE. TURNS OUT TO BE THE CRANKSHAFT POSITION SENSOR
SOURCE: P1345 Code on a '97 Chevy 5.7 in a Silverado
that code usually means the distributor was moved and the cam and crank signal sync is off,you mwill need a scanner capable of data display to reset it,it should be near or at 0 degrees,if you do not have access to a scanner your local shop should be more than capable of reseting it.hope this helped
