Scanned manual available but is too large to load here. Basically, all functions are handled by the phone, the headset's only control is the on and off switch.
You don't need a driver! This is a Bluetooth keyboard. What you need to do, is pair it with your Bluetooth device.
First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
You probably have the same problem I had. First, charge the keyboard. Enable Bluetooth on your device. Now, push the small black button marked "ID" on the back of the keyboard. The button needs to go in pretty far. This will generate the Bluetooth code needed to pair your Device. You need to enter the four digit numerical code generated by the keyboard. That's it! You are paired!
On your phone, make sure bluetooth is turned on (settings, general).
While
your phone is in discovery mode, turn your bluetooth device on and put
it in discovery mode ***(usually you have to hold the power button for 7-10
seconds)***
Your phone will find the device, and you will be
prompted to enter the devises PIN number (often 0-0-0-0). Your phone
should pair with the device then.
On
While
it in discovery mode (usually you have to hold the power button for 7-10
seconds).
On
While
seconds).
On
While
seconds).
