Sanyo PRO-700 Cellular Phone Logo
Posted on Apr 09, 2009
SPRINT SANYO PRO 700
WHERES THE SIMS CARD GO ON THIS SANYO PRO 700 .DO I NEED A SPECIAL SCREW DRIVER CUZ I HAVE A NEXTEL SIMS CARD THAT I WANNA USE ON THIS NEW PHONE
  • Anonymous May 11, 2010
    ok it may be a good idea to try opening the part wer the battery geos and there should be a place to put it and also on some phones,u usually need a boby pin or sumthin to put through a little hole on top of the phone
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Apr 10, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
2403
Points
11
Hey! I just got the PRO 700. IT DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
2answers
Does a european sim work in a sanyo vero? [sprint 3G phone (sprint service)]
Are you sure the phone uses a SIM card at all? Unless something has changed recently, Sprint phones do not use SIMs. You would need to speak to Sprint to confirm.
Need a driver for Sanyo Pro 700 phone
You can download it here:
http://shop2.sprint.com/en/software_downloads/phones/sanyo_pro700.shtml
I have a Nextel sim card in my boost phone i335 I need special. Code
Call Nextel and have them activate that phone to your account.
Nextel, Sprint, and Boost are the same company.
Nextel is the iden network,
Sprint is the CDMA network
and Boost is the prepaid network. But their owned by Sprint
Sep 02, 2011 • Cell Phones
1helpful
2answers
Sprint told me to remove the SIM card from a Sanyo Pro that has each contact showing up twice. I can't find the SIM card.
The Sanyo PRO-700 is like all Sprint phones and uses the CMDA network so no Sim card is used. You can take the phone to the Sprint store and have the clerk's use the transfer machine and that should delete the duplicate entries.
How do we transfer contacts from A Sanyo 700 pro to a Samsung Rugby II?
hopefully you are Sprint client........ have them do transfer all your contacts for you, it will be done 30 - 60 mins depending on how many you have and how many customers are ahead of you
Can boost mobile sim work in a pro 700
PRO 700 DOES NOT USE SIM CARDS! instead like the other sprint phones it uses the ESN/MEID number on the back. Just call sprint and tell them you want to do an ESN SWAP or SWITCH TO A NEW PHONE and they will ask you for the number under the battery. They will also walk you through activating everything including Direct Connect. It is as fast as Nextel traditional Direct Connect but it has a MUCH LARGER COVERAGE AREA FOR VOICE AND DIRECT CONNECT. Soon these phones will take control and the whole IDEN network Nextel uses will be converted to CDMA (sprints High Speed Network).
2answers
I have an active nextel i710 and want to move sim card to a i855 boost mobile,but i need a special unlock code.Can u help me.
Remove the battery from the phone. Let it remain out of the phone for 10 minutes with the phone off. Replace the battery and turn the phone on.
This is a problem with the phone trying to read the SIM card after being in another phone. Be patient. It may take several minutes for the phone to read the SIM.
1helpful
2answers
Driver for sprint mobile broadband card
Hi there.
Download the driver for the Merlin from here:
http://www.nextel.com/en/software_downloads/mobile_broadband/novatel_merlin_s720.shtml
Good luck and thanks for using Fixya
Special code
You'll need to contact Customer Service for Nextel to obtain the special code.
1helpful
Need i850 special code
Sorry, there is no special code. You can only use the correct Sprint Nextel SIM Card with this phone. If you are using the correct SIM Card, you will need to have this repaired at a local service center. This is covered completely by Sprint Nextel's ESRP (Equipment Service & Repair Program) and TEP (Total Equipment Protection), and can be done at any Sprint Nextel Service & Repair Location. If you do not subscribe to ESRP or TEP, the charge for the repair will be no more than $55.
Top Sanyo Cell Phones Experts
Sean Wright
Sean Wright
Kolbrun...
 Mikey
Mikey
Are you a Sanyo Cell Phone Expert? Answer questions, earn points and help others
