1998 Lincoln Town Car Logo
Posted on Apr 08, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Clicking Noise Coming From Under The Hood
I was driving home on the highway in my 98 lincoln town car. i was accelerating to pass a truck and brought it up to 82mph, the transmission shifted into gear smoothly, the engine reved and i after about 5 seconds i heard a pop and a rattling/clicking noise came from under the hood. i was alarmed to hear it but kept driving to the nearest exit. the check engine light then came on and started falshing until i deccelerated and brought it down to 65mph, and the noise seemed to dim and eventually stop; the engine light went off. to test it, i brought it back up to 80mph and it began rattling again but it was alot quieter and the check engine light only flashed once. i got off the exit and drove 2 miles home, without any noise or problem; the car acted and sounded perfectly fine. i lifted the hood in my driveway and nothing was physically wrong with the engine, everything was were it should be. i even reved it up to 4000rpm and heard nothing. its not the transmission i already checked this. what could it be???
  • cimbak1 Apr 08, 2009
    The fan belt was fine, i had it running when i looked under the hood and didnt see a problem. i also noticed that when i accelerated the clicking/rattling got faster, but then it slowed when i slowed down; and it eventually quieted down the second time around. but ill def check the belts again, thank you again!
  • cimbak1 Apr 09, 2009
    i had my friedn look at it, he is a mechanic. e found that the valve got stuck and by me accelerating i unstuck the valve. we determined this because i was extremely low on oil. so i filled it up, my friend reved the engine to the point where i thought it would explode, and it was fine, no sound whatsoever; and we re-examined the belt, everything is in order. thank you for the help!
Dar
Level 3:
President:
  • Lincoln Master 2,007 Answers
  • Posted on Apr 08, 2009
Dar
Lincoln Master
Level 3:
President:
Answers
2007
Questions
Helped
734577
Points
6454
Have you checked your belts? A piece of belt may have come off and been slapping under your hood, and then fell off completely. While it was slapping, your computer would have detected the slow down of pulleys etc. and caused your engine light to come on. Then when the piece broke off, everything would be back to normal. Let me know!
  • Dar
    Dar Apr 08, 2009
    You won't see the problem now, unless you look closely. And, yes, when you speed up, the fan belt turns faster, and the clicking would be faster. I think you should look very closely at the belt. All the way around. You won't see it when its running. There is probably a chunk, or a strip missing.
1helpful
1994 lincoln makes a loud metallic twisting and popping sound when accelerating
check water pump bearings Check power steering bearings. Check fan belt for condition and tension.
Rattling under hood
Sounds like time for a new engine to me. (severe engine damage due to oil loss or overheating)
Ac converted to r134 system just charged when i
You have a check valve,in a vacuum hose ,that is bad or a vacuum line that is sucked together,or has a hole in it under the hood,there might be a vacuum reservoir that may have a hole in it,it holds vacuum for the ac heat control doors,look under the hood.
Clicking Noise Coming From Engine
oil pump may have to be replace or clean the oil pump strainer must remove oil pan
6helpful
4answers
How to reset the change oil light for a 2007 lincoln town car. Hitting reset button doesn't do it.
FIRST press and release the setup button to display oil life= xxx
then press and hold the reset button for about 2 sec it should then display oil life set to 100%
Just pressing the reset button when the change oil light comes on while driving will not reset the computer
1helpful
2000 lincoln town car Clicking Noise Coming From Under The dash board sound like when you have your signal lights on but it is faster. use to go away when the car heats up. it is coming from the place...
This clicking is the Antilock brake system doing a self test. It's mentioned in the owners manual. Nothing to worry about but it should only take a minute and its best to let it fully cycle. Ned
Clicking noise under dash
Nah, no msjor wire storms. If your lights are flashing, then I doubt its the flasher. It is more than likely your ABS system cycling. hAVE YOUR WHEEL SENSORS CK'D / ADJUSTED FIRST. gOOD lUCK.
1997 Lincoln Towncar noise in dashboard
Is the noise coming from wiper area when you are driving on the highway? If it is the most likley solution is to replace the plastic peice at the bottom of the windshield that goes all the way across, on the outside between windshield and hood. when the wind hits it it makes noise.
Top Lincoln Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Lincoln Expert? Answer questions, earn points and help others
