Blank screen after xp welcome screen no power to keyboard
I'm working on an Asrock K7vt2 mobo with an AMD Duron 1.30ghz proc 128mb (pc133) sdram winxp. AGP 4x AMI bios v.3.31a Prob started after attempting to add 128mb more ram. I was already getting 1 beep at startup. After adding the ram, I began getting 1 beep, pause and 2 short beeps. PC will boot as far as the xp welcome screen then goes black never to get to the desktop. I also lose the keyboard at this point. I reinstalled xp, no luck same symptoms. I switched out mem for 512mb ddr still no luck. I took out cmos battery for a while (over 30mins.) Got different set of beep codes, set bios to default settings, and still same symptoms.
I have also tried fixmbr with no luck.
PC will boot to safe mode with a start bar and working kybd and mouse, but desktop still blank. Can anyone help, Please?
Thanks...
With the current setup, I get 1 beep a pause, then 2 short beeps. When my desktop is blank I lose my keyboard also, so I can't hit ctrl+alt+delete except in safe mode. I tried the ctrl+alt+delete in safe mode and it opened the "My Documents" folder. Oh, also, before I had this situation it was running very slow, even for 128mb and I kept getting a message for windows explorer asking me if I wanted to work offline or try and connect. This was also before I reinstalled xp. Could this be linked to my problem?With the current setup, I get 1 beep a pause, then 2 short beeps. When my desktop is blank I lose my keyboard also, so I can't hit ctrl+alt+delete except in safe mode. I tried the ctrl+alt+delete in safe mode and it opened the "My Documents" folder. Oh, also, before I had this situation it was running very slow, even for 128mb and I kept getting a message for windows explorer asking me if I wanted to work offline or try and connect. This was also before I reinstalled xp. Could this be linked to my problem?
Hey, I saw a post on another site where someone with the same problem was able to get a desktop with win 98. I've tried that and so far, so good. Next I think I'll try to find and install all my drivers, check my bios settings and try maybe win me or 2000 and see what happens. If that works, I'll try XP next. I'll post my results...Hey,
after restarting in ms dos mode i used F8 And F5, now I am in safe mode n my home screen, how do I get out of safe modeafter restarting in ms dos mode i used F8 And F5, now I am in safe mode n my home screen, how do I get out of safe mode
You can't post conmments that contain an email address.
Re: Blank screen after xp welcome screen no power to...
Ok, with your current set up, what beeps are you getting? Also, while you have a blank desktop, hit CTRL+ALT+DELETE and you'll have Task Manager come up, click File and then New Task and type in "explorer" without quotes and hit enter.
That should restore your desktop. Let me know how it goes.
Ah, when Windows Explorer asks you that, it's generally spyware that wants to hook into the Internet for some reason, sometimes to transfer activity logs or browsing habits to name a few things. As you have reinstalled the operating system to Windows XP, the spyware will now be gone, so that is not an issue to worry about.
The beep code signifies a video card error. You may well be looking to replace your motherboard, my friend as it's unlikely 3 video cards will cause a video adaptor error on the motherboard - before you do so, please do check them on another computer, just in case.Ah, when Windows Explorer asks you that, it's generally spyware that wants to hook into the Internet for some reason, sometimes to transfer activity logs or browsing habits to name a few things. As you have reinstalled the operating system to Windows XP, the spyware will now be gone, so that is not an issue to worry about.
PC66 SDRAM PC66 SDRAM is the original module speed of SDRAM. PC66 SDRAM was the earliest version of SDRAM and therefore came in a number of smaller megabyte sizes than later versions. Most early motherboards were rated for PC66 SDRAM. The available sizes are 32MB (megabytes), 64MB and 128MB. PC100 SDRAM
PC100 SDRAM was released after PC66 SDRAM and runs at a higher speed. It has the same number of pins as the earlier memory module and is capable of utilizing the same RAM slot. The only difference when installing this SDRAM in compatible computers with older systems (PC66 slots) is that the SDRAM will run at a slower speed. PC100 RAM comes in sizes such as 32MB, 64MB, 128MB, 256MB and 512MB. PC133 SDRAM
The last generation of SDRAM is PC133. The PC133 memory provided a speed upgrade and comes in larger sizes than previous generations of SDRAM. PC133 modules are backward compatible with older SDRAM slots. The PC133 memory, however, will be forced to run at the slot's slower bus speed (PC66 or PC100). The memory comes in sizes like 128MB, 256MB, 512MB and 1024MB.
Compaq Presario 700 Memory Maximum Memory 384MB Memory Slots 1 (1 bank of 1) non-removable base memory 128MB Machine name: Compaq Presario 700 CPU options: AMD Mobile Duron (900MHz) Chipset: VIA ProSavage KN133 HD Bus: Ultra ATA-66 Front Side Bus options: Memory Speed options: PC133 144pin SDRAM SODIMM
Hope this helps you out. Have a Happy and safe 4th of July weekend!
Unfortunatly your still running low end CPU power and low end agp graphics. Your going to pay 150-200 just for a fair PCIe/AGP HD/3D VC. If $200 doesnt hurt (and this is the lowest price best option), then might I suggest Mobo/CPU/RAM for around $200 that would do the trick and allow for future upgrades. You might also need a power supply. I just built one less than 3 weeks ago for a friend and it fairs against my own gaming comp.
MY PC... AMD ATHLON 64 X2 DCP 6000+ 3.01GHz
NFORCE6M-A V:2.0
8GB PATRIOT
XFX 8800GT AD 512MB
500W PS
NEW PC.... Gigabyte GA-MA785GMT-UD2 MB $90+/- AMD Athlon™ II X2 250 BOX 3.0GHz (CAME W/FAN)$70+/- AND 4GB OF DDR3 1066 RAM COMPATIBLE WITH MOBO $40+/- THE ONBOARD VIDEO IS CAPABLE OF USING 700MB OF RAM...RGB/DVI OUT.
It wont work, it will hang ur system. Ur motherboard supports but using Mutli-frequencies RAM is not possible, either u use SDRAM 512 BM PC133 or ur 64/128 PC100 RAM, You cant use all together.
that looks like an Albatron MoBo but I cant get onto the albatron website to confirm this
Feature
AMD Athlon™/Athlon™XP/Duron™Processor Socket 462 with FSB 200/266MHz 2 DDR266/200 Memory Sockets 6channel AC 97 Audio 2 ATA133 Channels, up to 4 ATA 133 IDE Devices 6 USB 2.0/1.1 Ports (4 ports by optional cable) Integrated 3D Graphics Engine
Processor
Socket 462 AMD Athlon™/Athlon™XP/Duron™Processor
FSB / Transport
200/266MHz
Chipset
North Bridge: VIA KM266 ( VT8375 ) South Bridge: VIA VT8235 I/O Chip : Winbond W83697HF
Memory
2 * DDR sockets DDR266/DDR200 unbuffered ECC/none-ECC DDR SDRAM up to 2GB
Expansion Slots
1 x AGP 4X slot (1.5V Only) 3 x PCI slots (PCI 2.2 compliant) 1 x CNR slot (AMR Type)
IDE / SATA Connectors
2 ATA133 channels, up to 4 ATA 133 IDE devices
Onboard I/O Connectors
1 x Floppy Connector 2 x USB 2.0/1.1 header (4 ports USB cable optional) 1 x CD_IN header 1 x COM (serial) port header (Optional COM cable) 1 x S/PDIF in/out header (S/PDIF in/out cable optional) 1 x CPU fan header with fan rotation detection function 1x System fan headers with fan rotation detection function 2 x 5 pin system panel header (Intel spec) 1 x Front audio header (Intel spec) 1 x IrDA header 1 x Case Open detection header 1 x Wake on LAN
I/O via Back Panel
PS/2 keyboard/mouse, 2 x USB(2.0/1.1),1xVGA ,1 x Com(serial), 1 x Parallel, 1x Game/Line-in/Line-out/MIC
Power
20-pin ATX power connector
BIOS Feature
2Mb Flash EEPROM Award BIOS with ACPI, DMI2.0, PnP, WfM2.0, Green Suspend to RAM (S3), Suspend to Disk (S4) Wake on keyboard, Wake on LAN/RTC Timer
Hardware Monitoring
2 FAN sensors, CPU/System voltages and temperature monitoring.
Try to separate the power cord of your monitor from your system or maybe if your using UPS(uninterrupted power supply) directly plug the UPS to the wall outlet. either you can use pretty voltage regulator to the regulate the AC power. if not solve the problem try to examine the your system power supply.
Depends on which AMD processor you would use. If Duron you could go to 1.8Ghz. If you use Athlon XP you could go to 3200+. Athlon MP 2.1Ghz and regular Athlon 1.4Ghz.
Hey,
