My Callaway II ceiling fan transmitter shows that air is being pushed down. However, the ceiling fan is actually pushing air upward.
I've tried everything I can think of to get the transmitter and...
If I recall, this fan has no external switches that can be operated - all of the fan and light functions are controlled by the remote alone. If this is indeed the case, there is little that can be done outside of hoping the problem is with the remote itself. If that is the case, replacing the remote is likely to be cheaper and less labor intensive - that is if you can find one.
From what I have read, this fan is no longer in production nor available for purchase. You may have luck bringing the remote to Home Depot - the main (possibly the exclusive) distributor of the Hampton Bay brand to see if they have fans on display that make use of remotes for fan and light control. If so, try to see if all your remote functions work. If you find that the reverse function no longer works - you should ask the sales associate about how to go about ordering a replacement remote. If the remote fails to work at all, you can 1) try a "shot in the dark" about ordering a an exact replacement remote - with the hopes that the remote itself is defective - rather than the paddle fan, or 2) start new by buying a new paddle fan with hardware switches for fan speed, direction and light operation AND a remote control module to perform a whole replacement of your existing paddle fan.
The "add on" remote control gives you many of the benefits of the remote only fan - but also provides a "back up" way to operate the fan should the remote or module fail. Had this been the style you have currently, you could operate the fan by hand until the remote and / or ceiling module was replaced.
I hope this helps and good luck. Please rate my reply. Thank you.
The model fan I originally selected to report my problem was not the fan I am having a problem with. My model was not among the list provided. So my question is does the solution sent to me apply to all ceiling fans or just the model I incorrectly listed? The model fan I have is a Hampton Bay,54" 5 bladed fan called the "Callaway II." It has a model number of 526 062.
Will the same sloution for fixing it still apply? I have not tried yet.
The fan I described in my initial note is not the fan I have. I could not find my fan in your list so I just picked one to see what kind of a response I would get. I'm not going to start working on a fan with advice about a different fan.
My fan is a Hampton Bay 54", 5 blade "Callaway II" Model 526062. If someone has some advice on how I can get this operating at full speed I would appreaciate it.
Do you have a loal repair shop based in Novato that does fan work?
the remote won't regulate the speed,light turns on and off no problem,the fan goes in reverse no problem,The fan will stay on high no matter which way it's running.Also I have 2 fans and switched the receiver from the one thats running properly.It ran fine,My question is the remote runs the light and the reverse no problem,just won"t turn the fan off or regulate the speed.
