Is there a way to turn off the loud beep noise on this elliptical?
SOURCE: Loud banging noise when using the Kettler elliptical trainer, ctr
This is a common problem for the CTR1, it actually sounds a lot worse than it is. It's just one of the 4 bolts that hold the front "pole" of the CTR1 in place that is broken. You will need to unscrew the bolts at the base (just move the plastic piece that hides the bolts up on the "pole"). After removing the pole you will need to remove the broken bolt from the inside of the "pole" with plyers. Then just put the pole back in the base, replace the screws (be sure to tighten them good). All will be good :)
This is a weak point of the CTR1, be prepared to run into the same problem again down the road...
