Cobra 148 GTL 120-Channels Base CB Radio Logo
A
Anonymous Posted on Jul 17, 2013
How to wire a microphone to a cobra CB radio - Cobra 148 GTL 120-Channels Base CB Radio
ken pullen
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Aug 24, 2013
ken pullen
Expert
Level 2:
Sergeant:
Answers
257
Questions
Helped
53447
Points
669
If you have the manual that came with the equipment it should show you a diagram of plug on the mic with colour code.
5 Related Answers
Anonymous
  • 156 Answers
  • Posted on Nov 23, 2009
SOURCE: Wiring Johnson Microphone to cobra 29 CB Radio
Use trial and error systemathically. If still refuses to work, mike and radio aren't compatibles.
Anonymous
  • 219 Answers
  • Posted on May 09, 2010
SOURCE: 29 LTD CB Radio: whats the color to number wiring for cobra mic...
This is for a cobra CA50 mic
1-sheild
2-white
3-red
4-black
Ironfist109
Iron
  • 3018 Answers
  • Posted on Mar 05, 2011
SOURCE: CB Radio - Cobra 29 WX ST - Need Chasis wiring
This one you will need a digram. any wiring you need is on that page. Good luck. www.cbtricks.com/radios/cobra/29ltd_29ltd_st_29wx_st/graphics/cobra_29ltdwx-st_29ltd_sch.pdf
Anonymous
  • 1212 Answers
  • Posted on Feb 02, 2012
SOURCE: instruction manual for cobra cb 19
http://www.cbtricks.com/radios/cobra/19dxii/graphics/cobra_19dxii_om.pdf
http://www.cbtricks.com/radios/cobra/19dxii/graphics/cobra_19dxii_sch.pdf
Anonymous
  • 9 Answers
  • Posted on Aug 04, 2012
SOURCE: where goes each wire color, cb radio ltd29 bt microphone
Slam it in your ***!
How to wire a Delta M3 to a Cobra 29 LTD Classic
Wiring a Delta M3 microphone to a Cobra 29 LTD Classic CB radio requires connecting the wires from the microphone to the corresponding pins on the radio's microphone jack. Here are the steps:
  1. Locate the microphone jack on the front of the Cobra 29 LTD Classic CB radio.
  2. Examine the Delta M3 microphone's wiring. It should have four wires: a black wire, a red wire, a white wire, and a shield wire.
  3. Determine the pin configuration of the microphone jack on the Cobra 29 LTD Classic CB radio. The pin configuration is usually printed next to the microphone jack or in the owner's manual.
  4. Connect the Delta M3's black wire to the pin on the microphone jack that corresponds to the radio's ground connection.
  5. Connect the Delta M3's red wire to the pin on the microphone jack that corresponds to the radio's positive voltage connection.
  6. Connect the Delta M3's white wire to the pin on the microphone jack that corresponds to the radio's audio input connection.
  7. Connect the Delta M3's shield wire to the pin on the microphone jack that corresponds to the radio's shield connection.
  8. Test the microphone by speaking into it while monitoring the audio output on the Cobra 29 LTD Classic CB radio.
Note: If you are unsure about the wiring or pin configuration, consult the owner's manual for your CB radio or seek assistance from a qualified technician. Improper wiring can damage your radio or microphone, and may result in poor audio quality or no audio at all.
How to wire a Sadelta M3 to a Cobra 29 LTD Classic
I believe to wire a Sadelta M3 microphone to a Cobra 29 LTD Classic CB radio:
The Sadelta M3 microphone has four wires: white, shield (bare wire), red, and black. The Cobra 29 LTD Classic CB radio's microphone jack also has four pins: Pin 1 (Audio), Pin 2 (Ground), Pin 3 (Transmit), and Pin 4 (Receive).
To wire the Sadelta M3 to the Cobra 29 LTD Classic, you need to connect each wire from the microphone to its corresponding pin on the microphone jack. The white wire carries the audio signal from the microphone's element to the radio, the shield wire provides a ground connection, the red wire activates the radio's transmit function when the microphone is keyed, and the black wire is used for receive audio.
Here are the specific steps to follow:
  1. Cut off the existing microphone plug on the Sadelta M3 microphone cord.
  2. Strip about 1/4 inch of insulation from each of the four wires in the Sadelta M3 microphone cord.
  3. Connect the wires to the pins on the microphone jack as follows:
  • White wire to Pin 1 (Audio)
  • Shield (bare wire) to Pin 2 (Ground)
  • Red wire to Pin 3 (Transmit)
  • Black wire to Pin 4 (Receive)
  1. Solder each wire to its corresponding pin on the microphone jack. You may want to use a multimeter to verify that each connection is solid and that there are no shorts or open circuits.
  2. Once you have soldered all the wires, test the microphone by speaking into it and checking that the radio's TX meter moves as you speak. Also, check that you can hear audio through the radio's speaker when receiving signals.
  3. If the microphone is working correctly, use heat shrink tubing or electrical tape to cover the soldered connections and provide strain relief for the wires.
Note that some microphones, including the Sadelta M3, may have additional features such as a built-in amplifier or power supply that require additional wiring.
How to wire a Superstar 507-5 microphone to a Uniden Washington base unit please?
It should just connect with the plug
eBay states.
This is a brand new Workman replacement omni-directional CB radio microphone. Features a 5-pin connector and a flexible coiled cord.
Wiring:
  • Pin 1 - Audio
  • Pin 2 - Ground
  • Pin 3 - RX
  • Pin 4 - Common
  • Pin 5 - TX
  • Compatible Radios:
  • Cobra 90LTD
  • Cobra 140GTL
  • Cobra 142GTL
  • Cobra 148GTL
  • Cobra 148-F-GTL
  • Cobra 2000GTL
  • Cobra 2010
  • Uniden Washington
  • Uniden Grant XL
  • Uniden Madison
  • https://www.google.com/search?q=connect+Superstar+507-5+microphone+to+a+Uniden+Washington
    How to wire a 4 pin ProComm microphone to work on a 5 pin microphone for a Uniden Grant XL
    The simplest way is to order a microphone adapter from ebay or a reputable CB shop. I have all my mics wired for standard 4 pin cobra. The standard 4 pin cobra is the most common and if you keep adapters handy then you can use all different kinds of mics on different radios.
    I have cobra ca61 desk mic i need it wired to my cobra 142 gtl home base. the base has 5 pins so i need my mic to be wired for 5 pin... any ideas?
    cobra 5 pin to 4 pin adapter on ebay around $5.00
    http://www.ebay.com/itm/WORKMAN-C4P5C-CB-RADIO-MICROPHONE-ADAPTER-5-Pin-COBRA-TO-4-Pin-COBRA-/121655850211?hash=item1c5340f4e3:g:e0AAAOxy2YtRsJ8n
    2answers
    D-104 wiring to a cobra cb
    Find your radio on this page and then look at the wiring diagrams
    2answers
    Top Cobra Radio Communications Experts
    Mike Cairns
    Mike Cairns
    eradiostore
    eradiostore
    Are you a Cobra Radio Communication Expert? Answer questions, earn points and help others
