SOURCE: I have a 1967-706 Farmall IH splitting a transmission
you must remove the plate from the bottom of the transmission. Look for a shaft that goes from the rear through a gear. Remove snap ring from in front of gear and it should roll apart then. On reassembly be sure to change gasket and all o rings to prevent hydraulic suction leaks
SOURCE: My 706 Farmall does not
linkage train has slack (worn) or spring could be broken that pulls the linkage into the slot and holds it there. for that you have to remove the floor plate then the trans cover. not too bad.
