I currently have a curve 9360 and this app error 608 reset came up what does it mean ?
SOURCE: my blackberry curve 8900 has a white screen saying
Hi, The BlackBerry smartphone displays the JVM 523 error message: For BlackBerry smartphones running BlackBerry Device Software version 4.1, this error may occur if a third-party browser channel icon has a HyperText Transfer Protocol (HTTP) redirect. OR When a locked BlackBerry smartphone with content protection enabled receives a Multimedia Messaging Service (MMS) message, this error may occur. This error only occurs with the Today themes in BlackBerry Device Software version 4.2.2. Download and install the latest version of BlackBerry Device Software on the BlackBerry smartphone by following these steps: Download the latest version of BlackBerry Device Software from your wireless service provider's web site. Install BlackBerry Device Software on your BlackBerry smartphone. BlackBerry Device Software version 4.1 (only) If you are running BlackBerry Device Software version 4.1, you need to complete the following steps: Complete one of the following, depending on the network on which the BlackBerry smartphone is operating: · For BlackBerry smartphones operating on a Code Division Multiple Access (CDMA) network, contact your service provider and have the BlackBerry Internet Service Browsing deactivated. · For BlackBerry smartphones operating on a Global System for Mobile Communications (GSM), remove the Subscriber Identity Module (SIM) card from the BlackBerry smartphone. Perform a hard reset on the BlackBerry smartphone. Turn the wireless transceiver off. Click the Browser icon. Expand the Browser Channels folder. Highlight a third-party browser push channel. Display the menu and click Delete Channel. Repeat steps 7 and 8 for each third-party browser push channel. Complete one of the following, depending on the network on which the BlackBerry smartphone is operating: · For BlackBerry smartphones operating on a CDMA network, contact your wireless service provider and have the BlackBerry Internet Service Browsing activated. · For BlackBerry smartphones operating on a GSM network, reinsert the SIM card. Turn on the wireless transceiver. Register the BlackBerry smartphone on the wireless network. Subscribe to the third-party browser push channels again. BlackBerry Device Software version 4.2.2 Change the theme on the BlackBerry smartphone to one other than the Today theme by completing the following steps: From the Home screen on the BlackBerry smartphone, select Options. Select Theme. Select any theme that is not the Today theme. Display the menu and select Activate. I Hope it helped you. Thank you for using ' Fixya ' and have a nice day!!
SOURCE: dear sir., i have blackberry 8900 curve
if the app required internet. then
go options - advance option - TCP
type the APN ( access point name ) you can get it from your bb service provided. click option n save
restart n try . if still the same issue persists then remove n redownload the app .
its if a normal application with no internet support is required. simply del n reinstall the app . do confirm if there should be no software ver conflicts.
SOURCE: blackberry curve 8330 app error 523
rather than write instructions I will refer you to blackberrys own set of instructions. Here is the link:
blackberry reset instructions
SOURCE: how do i reset my app error 523
Options, Security, General Settings then hit the menu key and select
wipe handheld.
If that doesn't work try this
Also you can do a hard reset:
1. Take out the battery.
2. Wait 5 seconds.
3. Press and hold the power button.
4. Put the battery back into place while still holding the power button.
