Cars & Trucks Logo
Anonymous Posted on Mar 25, 2009
What are the correct tyre pressures for a 2008 Audi A3 1.6 Petrol 5-door hatchback?
Arjun Komath
Level 3:
  • Master 1,170 Answers
  • Posted on Mar 25, 2009
Arjun Komath
Master
Level 3:
Answers
1170
Questions
8
Helped
439724
Points
3355
Audi A3 Recommended Tyre Pressures 1.6 96 - Onwards 28 28 32 40 1.8 96 - Onwards 28 28 32 40 1.8 SE 96 - Onwards 28 28 32 40 1.8 Sport 96 - Onwards 28 28 32 40 1.8 T Sport 96 - Onwards 28 28 32 40 1.8 T Quattro Sport 00 - Onwards 28 28 32 40 S3 99 - Onwards 30 30 36 40 1.9 TDi - 110bhp 96 - Onwards 30 30 36 40 1.9 TDi - 130bhp 01 - Onwards 28 28 32 40
Tyre pressure for vauxhall vetra
have a look here http://www.kwik-fit.com/tyre-pressure-search.asp
without knowing what model, size tyres / wheels you have we cant answer, go to the above site and enter your registration number
FIND CORRECT TYRE PRESSURE FOR A CITROEN BERLINGO VAN
See if this helps. In the U.S. the tire info is posted on the door frame of the driver's door. The link below lets you input exact info from your car and gives you Michelin's numbers. Pretty neat.
Looking for new tyres
Correct tyre pressure for audi tt
the tire pressure is usually shown on the door placard along with the year and vin #. pressure is probably 32 lbs.
1helpful
Nissan tyre pressures
the info will be in the drivers manual, or perhaps on the door jam or glove box lid. pressure can change by weight carried and tire size.
Tyre warning light stays on
Hi. if the tyre prssures are correct then you need to into the dash menu and select tyres and store the pressures. this will reset the light.
1helpful
2008 mazda 3 "!" light came on. What does it mean?
Low tire pressure. Look at the tire pressure sticker in the drivers door jamb, and set all of your tires to the correct spec. If you have a slow leak, or a bad tire pressure sensor, it won't go away on it's own.
1helpful
I need the correct tyre pressure for focus 2007 1.6
Is there not a sticker on drivers door, or door post with that labeled on it?
2helpful
2answers
I have a 2007 Audi A3 5 door hatchback Special but no handbook was included when I bought the car. My problem is that I do not know what the tyre pressure should be for this car and having had the car for...
Look inside the petrol cap! Otherwise:Audi A3 Recommended Tyre Pressures 1.6 96 - Onwards 28 28 32 40 1.8 96 - Onwards 28 28 32 40 1.8 SE 96 - Onwards 28 28 32 40 1.8 Sport 96 - Onwards 28 28 32 40 1.8 T Sport 96 - Onwards 28 28 32 40 1.8 T Quattro Sport 00 - Onwards 28 28 32 40 S3 99 - Onwards 30 30 36 40 1.9 TDi - 110bhp 96 - Onwards 30 30 36 40 1.9 TDi - 130bhp 01 - Onwards 28 28 32 40
Telephoned Audi Main Dealers around Manchester – Macclesfield very helpful, others either disconnected or not answering. Manual costs £21.85 (inc. VAT) + postage .... Too big to actually download and print, I suspect!
Billy Boy
What is the tyre pressure for ford escort hatchback 1996 1.392 cc
All manufacturers put the tire size and air pressure requirements on a label attached either to the driver door post, or the end of the door. If u can't find it, let me know.
2helpful
2answers
1998 RAV4 TYRE PRESSURE??
Thomas Heime is wrong, wrong, wrong! That is the max. pressure that the tyre can handle! the proper tyre pressure is written below the latch on the passenger side door. Open the passenger door, look at the label below the latch and there it is.
Top Audi Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you an Audi Expert? Answer questions, earn points and help others
