Samsung Galaxy S GTI9000 Smartphone Logo
Anonymous Posted on Jun 13, 2013
Fix screen screen cracked and the screen is not showing but the phone works
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Jun 13, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
0
Helped
6481
Points
39
The screen and instructions are readily available on the Web. Repairmen have sprung up all over who will fix it for <$100.
1helpful
3answers
How to Fix a Cracked Phone Screen?
no info generic answer search online their are multi sites that show how to
Aug 16, 2021 • Cell Phones
Screen blank on x836 turns on screen blacksout help thanks
Black Screen, Working Phone [Solved] - Phones - Cell Phone General ...
www.tomsguide.com/forum/id.../black-screen-working-phone.html
Dec 14, 2015 - 12 posts - ‎10 authors
I turn my phone off and then turn it back on, same result, black screen. I then tookout the battery and put it back in, same result. I took the battery ...
Why is my screen black but everything else works ... - iFixit
https://www.ifixit.com/.../Why+is+my+screen+black+but+everythin...
iFixitThe Samsung Galaxy S3 is a multi-touch, slate-format smartphone with ... I have a problem with my phone i dropped it and it works but all i see is a black screen ! ... was fine but then a couple of mins. later the screen started turning pink and when I .... i dropped my gs3, the screen cracked & the screen stays black, everythimg ...
Phone stuck on a black screen during or after a call? Here's ...
www.smartmobilephonesolutions.com/.../cell-phone-shows-a-black-scree...
Is your phone showing a black screen after finishing a conversation and not allowing ... causes and better yet some solutions to fix this issue on your cell phone. ... phone up to your ear, so that the phone will lock (turns on the black screen), ...
Jan 04, 2016 • Cell Phones
Samsung Galaxy Mega touch screen won't work
the digitizer is damaged . the part is approx $80. labor to fix maybe another $100
My touch screen on my lg ally just stopped working. how can I fix it
mos likely it is a cracked screen....even a minor crack not visible will cause it not to work........if the screen is fine then it might be loose ribbon connection or bad microprocessor or the phone is frozen/locked due to nmo more memory.....try to reset the phone.....to manufactures reset condition......if all else fails.....have the screen checked for cracked glass.....these screens have a liquid in between 2 pieces of glass and a grid template which act as a capacitor so that it responds to you touching certain co-ordinates on the screen....any cracks at all will render it useless and must be replaced, their is no way to fix the screen if it is cracked....good luck
2answers
I dropped my model No. A1241 phone and the touch screen doesn't work but it has no cracks. how can I fix it?
not having a crack on the screen doesnt mean your touchscreen will work. you said you drop your phone, it has a great possibility that it cause an internal damage to some of the microchip inside your phone that controls the sensors of your touchscreen.need to reheat the microchip inside it. open your phone and try to check for the microchip near the flex from the board of your phone going to your screen. then reheat it, but dont move it.
1helpful
2answers
Need new screen for htc aria i drop it and cracked the screen . .can it be fixed phone works fine
http://www.iphonerepair.com/htc-aria-glass-replacement/
You can get it repaired by sending it to them and they'll send it back fixed. It's pretty costly though.
I cracked the screen on my phone, is there a way i can fix it?
I thought the screen is damaged. so replace it.
Jul 08, 2009 • Cell Phones
Motorola V3c Cellular Phone
send it to motorola and they will charge you a minimal fee but they will repair it-need to replace the screen
2answers
Screen cracked
Id contact LG for info on a replacement screen, might cost alot.
If you have warranty maybe that would save you, but im not sure does warranty repair something caused by the user.
Top Samsung Cell Phones Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
