Sparepart Yamaha 25NMO 6L2 1996 model Chargingcoil for CDI unit..Or complete cdi with "everything"..It fire only at one cylinder, and the mechanics say it is the power supply to the CDI unit..
The power supply is common for all the coils.
Have you switched the coils (wires marked 1 and 2)? If still the same coil non sparking, replace that coil.
If the same output non sparking, check the pulser coil for that cylinder. Invert both pulser coil connections (white red and white black). If the miss is on the same cilinder, replace the cdi. If the miss is on the other cylinder: replace that pulser coil.
SOURCE: I have acquired a CDI 1998 to my Yamaha XJ600 Diversion 1993
hi mate. the cdi was changed in 1995 to accomadate a thottle sensor.pre 1995 the cdi was a square item. post 95 there tapered..
SOURCE: 83 yamaha tt600e no spark
The CDI unit on the 83 model (TT600) is located under the fuel tank and suffers from heat
exposure.The solution is to get specialist help to open up the sealed CDI unit and repair/
replace internal connections (which are readily available electronic components)
When you re-install it put some heat shielding material there to protect it and this
will be OK as repair will utilise stronger parts,I think.
Later models have the CDI unit moved to the head-stem area.
(this info from a Non-mechanic who remembers what was done to his TT in Australia, many years
ago)
SOURCE: I have a 1985 xv700 virago. one of my plugs are
follow the plug wire back to the coil and see if there are any breaks, if not might switch coil with the other one and see if the other plug now misfires, if so replace the coil, most cdi problems are not intermittent, typically they either work, or they dont.
SOURCE: I have yamaha xt550 1982 with a cdi electrical
take the cdi off and inspect it youll need a book by haynes or clymer @ a Borders be careful with the timing!
