Car Audio & Video Logo
Posted on May 30, 2013
Car problem My wipers let go on me ,,, I chek the nut that hold them, the fuse,and all connection
Hedox
Level 1:
Habit-Forming:
New Friend:
  • Contributor 5 Answers
  • Posted on May 31, 2013
Hedox
Contributor
Level 1:
Habit-Forming:
New Friend:
Answers
5
Questions
0
Helped
229
Points
53
Maybe you should try checking the motor that runs the wipers when you turn it on
2answers
2helpful
2answers
My 2007 santa fe was driven in the ice and the wipers were on but not moving, nowthat i go to use the car, the driversside wiper is not moving correctly and the pass. wiper is wiping over it, the wipe
wow , never turn you wipers on when the cars has snow or ice on the window EVER , you have to loosen the nut that holds the wiper on and re-adjust it to the other one , easy fix unless you work out the knurle that is what holds it in place easy fix ,unless you broke it
Windshield wipers went out on my 2000 nissan maxima
Im not sure the extent of the problem but if both went out, check your fuses, they may be under the hood or in the fuse panel within the car. Also you might want to check if the nuts that hold the wiper arms on arnt loose, if they are the rod that holds the wiper arm will move but with out the nut holding tight the arms themselves wont move.
2answers
Rear screen wiper has stopped working
Please check "fuse".
You can check manual of your car in order to find where fuses are located and which fuse is for rear screen wiper.
I hope this information helps.
May 11, 2011 • GPS
Wipers arms go all the way off my 1994 honda accord?
Are the wipers too long for the car, if so when buying new ones for example the car requires a 16 inch, buy them one inch less (15). If this is not the issue, take the plastic cap off where the wiper arm meets the car and you will find a mm nut. Holding the wiper arm in place, tighten the nut if it is loose and this should be solved.
2answers
Front window wipers wont work
FIRST CHECK FUSE TO WIPERS IF FUSE IS OKAY THEN YOU WILL HAVE TO TAKE A TEST LIGHT AND TEST FOR POWER AT THE CONNECTOR TO THE WIPER MOTOR IF POWER IS PRESENT THEN THE MOTOR IS BURNT, WILL NEED TO REPLACE ALSO POSSIBLE WIPER TRANSMISSION MIGHT BE BROKEN, ALSO NEED TO VISUALLY SEE
12helpful
Ford f150 windshield wiper bushing diagram. windshield wipers are not working , motor is going and the wiper arms will move freely when truck is not on
sounds like a loose nut. there are nuts that hold the wiper arms on, they may be under a cover but theyre at the base of the wiper arm. also there's a nut that holds the wiper linkage onto the wiper motor. if you can move the wipers independently, it's the nuts connecting the wiper arms.if you move one arm and the other moves with it, it's the nut holding the linkage to the motor.
2answers
My 98 saturn SL1 wipers do not operate evenly and drivers side may run off the windshield. what is wrong?
At the base of the wiper there is a nut under the decorative cover that holds the wiper on. You can remove this nut and pull the wiper, realign it and replace the nut. With a few tries even a novice can get them where they belong.
4helpful
Where is the windshield wiper motor on a 2007 Dodge Caravan and how do I replace it?
Wiper Motor: Service and Repair
Removal
REMOVAL
The front wiper motor comes as a unit with a wiper pivot on each end and mounts to a shaft that holds these two inner pivots.
1. Disconnect and isolate the battery negative cable.
2. Remove the wiper arms.
3. Disconnect the washer hose at the in-line connector located near the air cleaner housing.
4. Lift the cowl grille and disconnect the washer hose grommet from the hole in the wiper module. Pull the washer hose and the grommet
completely through the wiper module tub hole.
5. Remove the cowl grille.
CAUTION: Be careful not to scratch the cowl grille on the corner of the hood.
6. Remove the four brace nuts holding the wiper tub to the lower windshield fence.
7. Remove the four bolts underneath the wiper tub inner brace holding the tub to the bulkhead.
8. Remove all four inner support brace mounting nuts and pull the inner braces just free of the mounting studs.
NOTE: The wiper tub will drop down slightly.
9. Disconnect the driver and passenger side wiper link ends at the inner pivots.
10. Remove the two left wiper motor assembly mounting nuts.
11. Remove the two right wiper motor assembly mounting nuts.
12. Partially lift out the wiper motor assembly out of the wiper tub.
13. Disconnect the wiper motor electrical connector.
14. Remove the wiper motor assembly the rest of the way from the wiper tub and remove from vehicle.
Installation
INSTALLATION
1. Install front wiper motor assembly onto wiper tub.
2. Connect the electrical connector to the front wiper motor assembly.
3. Install the four mounting nuts. Tighten nuts to 9 Nm (80 in.lbs.).
4. Push the four inner support braces onto the studs and install the four nuts. Tighten the nuts to 9 Nm (80 in.lbs.).
5. Install the four bolts underneath the wiper tub inner braces that hold the wiper tub to the bulkhead. Tighten the bolts to 17 Nm (150 in.lbs.).
6. Install the four nuts holding the wiper tub to the lower windshield fence line. Tighten nuts to 7 Nm (65 in.lbs.).
7. Apply grease to drive link bushings.
NOTE: Make sure to use Mopar(R) approved grease.
8. Attach the driver and passenger side outer wiper linkage to the inner pivots on the front motor assembly and firmly snap into place.
CAUTION: Do not apply too much force to engage link bushing or damage can occur to the drive link bushing.
9. Position the cowl grille in place.
10. Install the washer hose and grommet into the wiper tub.
NOTE: Be sure to properly seat the washer hose grommet into the bottom of the wiper tub.
11. Connect the washer hose at the in-line connector located by the air cleaner housing.
12. Install the cowl grille.
13. Connect the battery negative cable.
14. Verify that the wiper motor is in the Park position by cycling the wipers system. When done, remove keys from ignition.
15. Install the wiper arms.
16. Align the wiper arms and tighten nuts to 35 Nm (25 ft.lbs.).
17. Install the wiper arm nut caps.
When trying to clean the front car glass... nothing happens...
well,you may need to specifie if the problem is the wipers or the defroster;if are the wipers verifiy the electric motor that activate the wipers,if you refer to the defroster chek the A/C filter it could be clogged.buena suerte!
Top Car Audio & Video Experts
xxxxxx xxx
ZJ Limited
ZJ Limited
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
