Cars & Trucks Logo
Robin Hopkins Posted on May 10, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1997 Toyota Avalon. Sometimes just makes a clicking noise when trying to crank it. Sometimes it trys to turn over then stops and makes the clicking noise again. Usually starts if you keep trying. Took 15 minutes the other day but finally cranked. It sometimes goes two to three wks and cranks first time then starts the clicking noise again. Seems to be worse when its raining and/or cold. Have been dealing with this over a year. Dont have another car to drive while mechanic trys to find whats wrong also have very little money to spare. Can someone please help?
max carson
Level 3:
  • Cars & Trucks Master 7,627 Answers
  • Posted on May 10, 2013
max carson
Level 3:
Answers
7627
Questions
Helped
1015296
Points
21773
Have the starter or solenoid checked. It's possible to get second hand parts from a Salvage/Breakers yard. If you don't mind getting dirty and can use basic hand tool. You may want to invest in a Repair Manual: http://www.amazon.com/gp/product/156392336X/ref=as_li_ss_tl?ie=UTF8&tag=toyota0d-20&linkCode=as2&camp=1789&creative=390957&creativeASIN=156392336X It can be very useful for a DIY'er .
5 Related Answers
Anonymous
  • Posted on Feb 03, 2009
SOURCE: Car will not crank sometimes unless you turn the key many times.
Check battery connections. Sometimes a weak connection will fail under very high loads like starting.
Anonymous
  • Posted on Feb 23, 2009
SOURCE: nissan 1995 maxima keeps stopping
I had a similiar problem with my 95 maxima. It turned out to be a bad MAF sensor. Check it out and make sure the sensor is not dirty. you can try cleaning it with a MAF sensor spray. I replace my with one from the junkyard.
Jonah Oneal
  • 14092 Answers
  • Posted on Oct 28, 2009
SOURCE: Toyota Corolla 1995 starting problem with loud noise
CHECK THE STARTER.MAKE SURE ITS NOT LOOSE.IF ALL IS GOOD.THEN THE STARTER COULD BE BAD.IT COULD HAVE WORN DRIVE GEARS OR THE FLYWHEEL COULD HAVE WORN OR BROKEN TEETH.IF YOU REMOVE STARTER TO CHECK IT AND FLY WHEEL MAKE SURE TURN OFF RADIO SO YOU WONT LOSE PLAYING CODE.WHEN YOU REMOVE NEGATIVE BATTERY CABLE.
Roger Foster
  • 701 Answers
  • Posted on Mar 20, 2010
SOURCE: 92 toyota camry timing belt not turning car quit
Hello tim42220: y name is Roger and I will help. If the timing belt does not turn when you crank the engine the belt is bad. The belt has a habit of striping the teeth of a the crankshaft gear. This engine shows to be a non-interference engine. That means if the belt breaks the valves should not bend. This is something you should be able to do if you are mechanically inclined. Main thing is to be sure all timing marks are right. I would strongly recommend replacing the water pump at the same time. The water pump is turned by the timing belt. Should the water pump go bad it will also damage the timing belt. They do make a timing belt kit that includes the belt and all new timing belt idler pulleys. You will need to reload the belt tension-er. This is the worst part as it is hard to reset the plunger. Easier to by a new one but they are not cheap. If you look at the new belt you should see two solid stripe markings and one stripe that is a dotted line.I would also replace the camshaft seals as they are the reason for the oil leaking onto the timing belt. When installed correctly the marks align with the timing marks on the engines cam and crankshaft. Enclosed is a picture of the timing marks.Should you need further help please just ask. Please rate your answer. This way I know it helped. Thank You for using Fix Ya. Roger6f56668.jpg
Anonymous
  • Posted on Aug 05, 2010
SOURCE: I have a 2000 toyota avalon ignition problems
Hello I have simular problem the ignition on is stuck in that position with the key turned off and out of the ignition switch.It feels like the key switch is spinning freely in the ignition. Do I need an ignition switch?
1997 Toyota Avalon. Problem: Mornings, won't start until repeated cranking warms engine a bit, then holds idle well (without pedal assistance) and starts and runs flawlessly all day.
Fuel pressure regulator may not be working properly, allowing fuel pressure to bleed off overnight. Try (before going to crank position on key) turning the key on for 3 - 5 seconds, then back off. Do this three or four times. (The fuel pump will run for 3 - 5 seconds before the ECM turns it off if you don't go to the start position.) This should allow pressure to build to what is needed initially to start the engine. Now try to start normally. If this works, you need a new pressure regulator. It is located either in the fuel rail, or on the fuel pump itself.
My 2001 toyota avalon has a clicking noise that comes from the starter relay fuse in the fusebox when I turn my car off, how can I make it stop.
I think the first step is to replace the relay. If that doesn't work I'm not sure where to go from there. This is a strange problem.
1997 Toyota Avalon is making a whinning noise when I turn my steering wheel and when am sitting still at a red light.
Please check the power steering reservoir and make sure that you have adequate amount of power steering fluid.
1997 toyota avalon will not crank or start horn blowing and lights flashing security light on.
Try unhooking your battery for about ten mins. This might reset your security system. You might also try locking all the doors and then unlocking with the key.
1helpful
Avalon won't start, fast clicking noises
Sounds like a dead battery issue. If someone can jump start you with battery cables connect red to red post on battery and black to your car frame or other ground. If the car starts easily it indicates a discharged battery. Then you need to determine why the battery is discharged. If you can drive to a local autoparts store they can use a machine to do a battery and charging system diagnosis at the curbside. Autozone, Advance, or Oreilly all do this. If the battery is the original from the car when purchased it is probably time to replace it. If its a new one (2 years or less) the culprit may be the alternator. The clicking noise is a dead give away that its a battery or alternator issue. The clicking by the way is the starter trying to engage and turn motor over to crank it. Its not getting enough power to turn the engine over (a tough task) and is clicking.
Car won't start
It won't crank? Does the alarm system works? Like locking and unlocking the doors? If that work, check cranking voltage to starter solenoid with a test light. But before, check all fuses under dash and hood. Make sure battery connections are clean and tight. There is more but try this for now. Let me know of the solenoid test and please ask any questions.
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
