Have a fully working Nikon F4s... but just destroyed its shutter curtain! Have also an older F4s whose shutter I can use to repair the first camera. How do I remove / install the shutter unit?
SOURCE: nikon f4s
F4 has an electronic shutter so check batteries ( see enclosed image ). If your batteries are fresh but still no power ( see if display comes on in view finder ) clean contacts in the battery holder. If still no joy camera should go in.
SOURCE: Nikon F4s battery holder
Just found this post, so you might already have one, but have you tried eBay? I got one on there for just £8 sterling (around $15 US) and when it arrived it was in almost new condition. The guy even threw in 6 rechargeable cells, which looked new (and I'm still using them) which must have been worth the £8 I paid him, without the MD21!
Good luck.
SOURCE: chronic sticking shutter on older Nikon
If the shutter doesn't stick on the M90 position, the problem is electronic. If it does, the issue is mechanical. Try the battery check. Hold it for a few seconds. If the LED goes out, the issue is most likely with the batteries. Use really fresh, top quality batteries. Use only silver oxide batteries, not the alkalines that are often substituted.
SOURCE: Touched the shutter curtains
Yes it will have an affect on your shooting. The curtains will not operate correclty if they are opening and closing at different speeds and / or not closing or opening completely. Your film will expose at different levels, and you will not get a correctly composed shot. You could try to coax the curtain back into place by GENTLY rubbing it with a Q-tip in the direction it is supposed to go. But those things are fragile and can be fickle. Your best bet is to take it to a shop.
SOURCE: Nikon N55 camera locks up
The F-- indicates that the camera is not communicating with the lens. There are several reasons for this.
The lens is not capable of communicating. If it's an old lens, without the electrical contacts, then you'll have to set the camera to Manual (M) mode in order to use this lens.
If the lens has an aperture ring, set it to the smallest aperture (biggest F/number) and lock it (if it has a lock).
If the lens has no aperture ring, then the contacts may be dirty. Remove lens, clean contacts on back of the lens and in the mount on the body, then reattach lens.
If that doesn't do it, then either the camera and/or the lens may require service.
