Muslim shower fix but its leak I change hose but still same
SOURCE: The shower hose leaks from the connection between shower hose and
have you tried teflon tape? wrap it around about 7 times and you will be fine.
SOURCE: Kohler shower hose leak
If the problem is solely because of the rubber washer with screen you can buy any cheap replica hose and use the washer that comes with it. If the issue goes away you are done. If not, switch heads and see if the issue follows the head. If it does then there would be a crack in the head at the connection. If neither solves the issue then you must buy a new hose.
