Awhile back I got my ipod touch wet. I could see condensation under the screen so I turned it off and let it dry. I waited till I could not see any moisture. When I turned it back on it worked fine for a short time, maybe 2 days. Then I started hearing a lot of static. Soon after thats all I could hear. Everything else still works, including the big port. However I can get no sound from the headphone jack. Can I fix it myself, or is it worth taking to a repair shop?
Sounds like you just need the ipods headphone jack replaced.
Try either http://www.ipodrefresh.com or http://www.ipodrecharge.com. They specialize in ipod repairs.
SOURCE: How do I fix a bad connection with the headphone
Hi, this seems to happen on a lot of mp3 players , usually when you wiggle the headphone in the jack the sound cuts in and out, its the result of the headphone jack bending the metal contact inside the player or can be due to a build up of dirt/ grime in the socket.The problem generally gets worse as time goes on
if you have tried it with different headphones still get the problem and its still under warranty I would get on the apple site or down to you local apple centre and try and get a replacement.
Sometimes a spray of deoxit (plastic conductive lubricant /cleaner)
in the socket does the trick , but I would strongly reccomend trying to get a replacemnt
