Posted on Mar 16, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RZ-8903AV no output - Sansui RZ-8305AV Receiver
Francisco Mauricio G
Level 3:
Genius:
  • Sansui Master 1,551 Answers
  • Posted on Mar 16, 2009
Sansui Master
Level 3:
Genius:
Answers
1551
Questions
Helped
525450
Points
4192
Audio amplifiers IC´s damaged
My motherbord not output in audio
Hello here you can download a manual and the right drivers:
http://www.gigabyte.com/products/product-page.aspx?pid=1767&dl=1#dl
Check ALL your connections on the mainboard
and also the jumpers.
Uninstall the old drivers before you install the new.
Good luck
LG RZ 20LA90standby light flashes from red to green
Hi, this description usually indicates power supply failure, you can verify this by checking the output voltage of power supply. Cause of the error can be electrolyte capacitors. You can identify them by swelling at the top of the condenser. If you have the technical ability? so there are a few more options for testing. In any case always possible to replace all power supply. Good luck! Let me know if everything worked out, or if you need further guidanc
1helpful
1helpful
Use of AV2 input sound socketsto play ipod
The sound is muted unless a video signal is detected on this TV. The only work around would be to connect the camcorder or some other active video to tha input but using the IPOD for the audio.
1helpful
2answers
No Sound output im using Gigabyte 7VM400M-RZ
Yes without the jumpers in the correct position the on-board audio won't function. Just follow the diagram. Make sure that there is no power to the board before you make adjustments to the jumpers just to be safe. It's also good to ground yourself by touch the case (if it's metal) before you touch any of the components and or motherboard.
No Audio OutPut When Cooling Fan Starts
I have the same rz 6880 av 5.1! bt im not facing that problem. Iv connected my Bose III series speakers to it...and it plays well. Maybe you need to check your system with a qualified personnel.
Top Sansui Audio Players & Recorders Experts
 Grubhead
Grubhead
ADMIN Andrew
ADMIN Andrew
Are you a Sansui Audio Player and Recorder Expert? Answer questions, earn points and help others
