Heat climate control doesn/t blow warm air when on lower setting
Liberty 2002 heater settings do not work on 1 & 2 but 3 & 4 work. Also driver seat belt button sticks so you can't unlock and once you get it to open you have to force button to close? Thank you.
I have the same problem with climate control. I changed the controls out but didn't help. I have the same problem with climate control. I changed the controls out but didn't help.
You can't post conmments that contain an email address.
this part has many names blend door actuator etc. It is car and car option "Climate Control" feature specific and located under the dash.
Before replacing confirm that the inlet and outlet heater hoses are both to hot to hold. The hoses connect at the fire wall on the van and if the return is not hot with setting to full heat than there is a restriction in the coolant path through the heater core.
The heater door actuator is the most likely culprit. If the air is bi passing the heater core it will be at best warm. Raising and lowering the temperature setting the movement of the door can be heard.
Are you able to control the driver side air temperature at the dash registers? If not and you can control the passenger side of the dual climate system then you have an issue with the air temperature control door (moves between the heater core heated air and the AC evaporator cold air stream) deep inside the dash or the electric actuator that moves it or in most cases both.
Jeep Liberty heater not blowing hot air Questions & Answers ...
www.fixya.com > ... > heater not blowing hot air > Cars & Trucks > Jeep
Jeep Liberty cars & trucks heater not blowing hot air questions and answers. Ask your Jeep heater ... My 2005 Jeep Liberty will not blow heat through ... properly.
warmth comes from the heater in the car
if it is climate control check the climate control module
check for heater control in the vent settings as the hot water tap may not be turning on
I have a 2000 pontiac grand prix with a digital climate control system.
The heat quit working, it doesn't blow out any heat. Now that it is warm
outside the air stopped blowing out any air. The digital temperature on
the climate control is not correct. When it states that it is below 30
degrees on the ext and it is warm outside the air wont be cold. Once it
starts going above 30 degrees the air gets colder. Today the blower stop
working all together. Was told it maybe the climate control unit was
bad. You can hear the door opening/shutting when you switch the temp
from cold to hot. But there was no heat blowing out whatsoever in the
winter time. Could you please give me your opinion on whether or not it
is the climate control unit or something else?
normal for an engine to start at elevated rpm and then die back as it takes a few seconds for the ECM doing it's sensor checks and idle back to the correct idle speed
check the idle rpm with an external rpm counter as most in dash units are inaccurate at rpm lower than 1000
as for the temperature
If you have a climate control module, it uses a mixture of heater and ac to maintain the temperature that you have set
so check it for operation
generally this is caused by a "blend door " motor (actually a vacuum control) not working. I don't have a diagram on this but if you watch the motors mounted to the heater box under the dash, and operate the control, you likely will find one not moving (check all positions including a/c)
