Baby Gear Logo
Marcie Williams Posted on Apr 17, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Replacement seat for cap barbell omega triangular seat
Marc Cohen CPSTI
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 158 Answers
  • Posted on Jul 02, 2013
Marc Cohen CPSTI
Expert
Level 2:
New Friend:
Cheetah:
Answers
158
Questions
0
Helped
25883
Points
177
This is an exercise bike, not a child seat!
Contact the manufacturer
Omega elliptical repair manual
what is the make, model and serial number?
Need manual for omega elliptical model number coe130
Try this link, I found a manual there as of July 26 2012
http://www.managemylife.com/mmh/lis_pdf/OWNM/L0709407.pdf
Personally I need power supply specifications for this unit, they are not detailed in the manual.
-Jeff
I would like to take out the cover of my alpha omega seat in order to clean it. How do i do it ?
Hi
There is a portable shampooer/sprayer that attaches to the hose ( the long one that makes the kirby a canister vacuum). It should have come with your attachments. Looks a bit like a gun without the tank attached to the bottom...the tank screws on.
To use it you would put the fingerguard attachment on the front of the kirby where the powerhead would normally go and the hose with the portable shampooer where the bag would go.
The tank on the portable sprayer/shampooer has lines to indicate how much water and shampoo are needed.
Be sure to put the mesh nozzle (sort of a triangular shaped thing with a piece of mesh along the front that attaches to the front of the portable sprayer) on the front of the portable sprayer if you want to shampoo..otherwise it will just spray a mist. The triangular piece with the mesh screen is what produces suds.
Vacuum the furniture thoroughly before shampooing. Once you've covered it with suds, pop the suds into the fabric using your hands...working the bubbles into any heavily soiled areas with a soft brush.
Then let it dry. 15 minutes to and hour depending on the amount of solution used.
Hope this works :)
16helpful
2answers
Cosco Alpha Omega Elite can't get straps back on right!
replace harness: 1) take **** harness and place metel bracket through the base of the seat(slot in shell) make sure buckle is facing out and not inwards. slide metal clip under small tab and push down on clip until it snaps in and locks into place... 2) thread harness without latch plate or harness retainer down through slot on one side of shell, under seat and up through slot on other side. 3) thread latch plate(clip that goes into ****clip)harness retainer onto the harness making sure they are correct. 4) thread harness end through other slot 5) make sure the harness goes over the barbut under the plastic bar, then fit loops on harness ends onto the harness bracket that looks like a triangle(kind of) 6) from the front even up harness to fit properly. And there you go the rest is pretty straight forward the base is pretty sraight forward to attach...
Replacement part
I just received a Cosco alpha omega car seat and the between the leg latch that the straps snap into is not working any place I can find a replacement part for it Heidi
15helpful
2answers
Needing replacement straps for Cosco Alpha Omega 22-150
Hi, i found something on amazon... take a look: Amazon com Cosco Alpha Omega straps. I hope this was helpful. cheers
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
ZJ Limited
ZJ Limited
john h
Are you a Baby Gear Expert? Answer questions, earn points and help others
