Vivitar ViviCam 20 Digital Camera Logo
geoffrey ayre Posted on Apr 06, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Driver for vivitar20 to work on windows7
Not able to down load photos presume driver on disk not compatable with windows7
Anonymous
Level 3:
  • Vivitar Master 32,281 Answers
  • Posted on Apr 06, 2013
Anonymous
Vivitar Master
Level 3:
Answers
32281
Questions
Helped
7913594
Points
102259
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
1 Related Answer
  • 102366 Answers
  • Posted on Aug 09, 2012
SOURCE: windows 7 will not let
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Afterinstallation of drivers on windows7 64bit my printer doesnt print panasonic dp-8020p,what could be the problem?
go on line a down load the driver from the Panasonic site and forget the windows drivers as they seldom are compatible with the manufacturers drivers
Cannot get a driver to load off line. 64 bit windows7 no disk
First run Delete Print Jobs to remove any stuck print job in the queue.
Disconnect the printer.
Download and run the patch(printer cleanup utility) until it prompts you to restart your computer.
Restart your computer. Make sure the printer is removed.
Manual Printer Driver Removal
Download the Vista 32-bit drivers for Windows 7 32-bit or the Vista 64-bit drivers for Windows 7 64-bit. Install the Vista drivers in the Vista
Compatibility mode You'll get a message, the printer is not connected. Connect the printer at this time(powered on).
Links to the patch/drivers can be found at...
Dell 964 Photo All-In-One Printer owners thread (W7)
Rick
I down loaded driver dic on to my hp 6400 w/wndws7 and the lap top reconises argus 1500 as a usb dual camera, detective search didnt +could not locate anywhere and noted that there is no software for this...
Welcome to Fixya
Download the driver from this link. Click download argus 1500 driver then enter the code written below then click download.
Thank you for using Fixya!
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Can't find a driveer for my lexmark x1185 printer that supports windows7. my disk that came with the printer will not load. can anyone help? I also went to lexmark website and it had nothing.
Use Vista Driver in Windows 7. Windows Vista drivers are compatible with Windows 7.
Driver Support
For many of Lexmark products, the Vista driver will work in the Windows 7 environment.
DOWNLOAD THE VISTA DRIVER:
http://support.lexmark.com/index?page=product&linkSelected=node0&locale=EN&userlocale=EN_US#1
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
My cam is not compatible to windows7
Here is how to Install them so they work. Download your XP driver you wish to install. If it's in a zip/rar file then extract it to your desktop. You should have a simple .exe file sitting on your desktop to install the drivers, as normal for XP. Right click the .exe file and select "Properties". Then select the tab called "Compatibility" Now check the box next to "Run this program in compatibility mode for:" Make sure "Windows XP Service Pack 2" is highlighted. Now apply the settings and run the installer. This should work for most drivers, but not all. make sure you install and run all.any programs as Administrator.
1helpful
2answers
Is HP Deskjet D4160 compatible with windows7 ultimate?
yes, just download a driver from hp official website, install and all done. :)
4helpful
2answers
I have windows7 and a quickCam model number
go to link
choose windows 7 and 32 or 64
and download
I just bought the EasyCam Pro today and the disk says Windows 98, 2000, ME, and XP. I have Windows 7 and when I loaded the disk and clicked on drivers it froze up at 70%.
I would suggest you trade it in for a windows7 model - Logitech or Microsoft
If that's not an option - download the software from here and run the webcam in Compatibility mode
http://jascoasia.com/support/software-downloads.asp#pccams
Top Vivitar Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
