2000 Mercedes-Benz S-Class Logo
Posted on Feb 27, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The key switch
I have this problem : the key switch is not working even i cant turn the car on ! this problem start when the brak light turn on so i stoped the car and after 2day i tryed to start the car on but i could'nt the key switch is no turnning ! the car is s320 class 2000 model ! what sould i do ?!
  • Khaled7373 Mar 16, 2009
    Dears,
    I have the same problem and I have the same car with the same model, I tried the above mentioned solutions but they did not work, I think if I reset the key code it will work, if that is correct please advise how can I reset the key, otherwise your assistance in finding a solution is highly appreciated
    Best Regards
myearwood0
Level 2:
  • Expert 93 Answers
  • Posted on Feb 27, 2009
myearwood0
Expert
Level 2:
Answers
93
Questions
0
Helped
43985
Points
244
Check your battery on the car if under 12v boost with jump pack or next car .then try.if batery is flat and this doesnt work then try disconneting battery for 5mins then retry with boost.if battery is ok then wiil be immobiliser fault as the key is not bein recognised.
My 1991 buick park ave shifter is stuck in park,it cranks but cant move shifter to reverseod drive to move car,can you help,tony.
I have seen in the past a failure of the brake light switch...try unplugging it and by passing it
My gear shift is stuck in park. The car starts up fine, but shifter wont budge.
the fuse is bad for shift lock solenoid. Read owner manual section on brak-shift interlock. Check fuse for nbrake lights. Brake lights work.
Owner manual has emergency by pass procedure. I think you turn key to OFF and then shift to neutral and start car then. Next time in park, you have to repeat.
My daugther has a Saturn sl2 v6, she went to give her grandpa a jumstart using cables but grandpa decided to start up his car before i turned the ignition on her saturn. Grandpas car started right up but...
CHECK FOR BLOWN BRAKE LIGHT SWITCH FUSE OR SEE IF BRAKES LIGHTS WORK.IF YES HOLD FOOT ON BRAKE PEDAL MAKE SURE TRANSMISSION SHIFT ALL THE WAY IN PARK.IF ALL IS GOOD.SOUND LIKE KEYLOCK CYLINDER BROKEN.IF IT WAS SECURITY THEFT SHUT DOWN YOU WOULD SEE SECURITY LIGHT.AND THE KEY WOULD TURN BUT CAR WONT CRANK.JUMP START CAR AGAIN.IF BATTERY POWER LOW THE BRAKE TRANSMISSION SHIFT INTERLOCK NOT GOING TO ALLOW IGNITION KEY TURN IN SWITCH.
2helpful
2answers
The shift lever is locked in park position...cant even press the button on it.What to do? (2006 Chevy Impala LTZ)
Take a look and see if the brake lights are working,the power to release the shift lock comes from the brake switch when you step on the brake the shifter is unlocked. i had a few of these that needed new brake light switches, first try starting the car and stepping on the brake pedal as hard as you can and then try shifting,if this works replace brak switch, next if that doesnt work check the brake light to see if they work if not or if so check all fuses even under the hood fuse box, hope this helps. here a picture of the shift release soleniod it on the steering column, dissconnect and slide by hand to release shifter until repaired.0b1056c.gif
Cant get brake light to go out
make sure the brake light switch is mounted and adjusted properly. they have been known in older cars to actually fall out of their mounting hole which in turn makes the brake lights stay on all the time. if it all looks good then it probably needs to be replaced. most new switches are self adjusting so that helps!
2001 aztek turn on key lights come on wont start
sounds like the ignition lock cylinder has gone bad call a locksmith.
1helpful
90 honda accord wont start
The ignition switch is wore out.
My car wont move out of park and the braks lights arent working.
my ford taurus did this to me too.... your car wont move out of park because it might be the neutral safety switch because your brake light connector piece might have come undone...
now first off the brakes (my switch was above my brake pedal) and just make sure its clipped in and then your neutral safety switch should go of and you can put it into gear.
if you cant find the brake thing to see if its unplugged just turn your key slightly on before all your dash lights come on and put the car into neutral and then start your car and you can put it into gear.
Top Mercedes-Benz Experts
ZJ Limited
ZJ Limited
xxxxxx xxx
Arnie Burke
Arnie Burke
Are you a Mercedes-Benz Expert? Answer questions, earn points and help others
