Apparently I am not the only person who can not find a soluntion how to reset the hour/service meter on my 24 HP sears 5500 tractor mower. I have researched for over 2 hours and find no soluntion except you want to send out a technician at, $101.00 service call. Something so simple with no help from sears except more money after I spent over $2000.00. Sears and K-Mart are a joke anymore. No wonder, Sears used to be a name you could depend on but now I see why you going down hill. I won't buy any thing else from Sears! I KNOW IT DOESN'T MATTER TO YOU, SO HAVE YOURSELF A WONDERFUL DAY!!!
SOURCE: Sears 19 hp twin 42 inch tractor, won't start if hot
Hi
Two things come to mind. First it could be not getting enough fuel when hot due to carb adjustment being too lean. That could be that the float level in the carb is set too low or the low speed jet is set too lean. When cold the choke circuit in the carb supplies the extra fuel required.
Second in some enjines that have low compression they start cold but when hot the compression drops below 60 psi and makes starting very difficult until engine cools down.
I suspect a fuel problem.
SOURCE: Craftsman 17.5 HP 42 in mower stops after approx 1/2 hour of use
I have an 18 HP B&S 42" Craftsman with the same problem. Carb has been rebuilt and fuel filter replaced. Have cleaned the vent hole in the fuel tank cap. Nothing has helped. Choking the throttle will keep it running for a few more seconds but it eventually stalls out only to start again in 5-10 minutes which keeps me thinking its a fuel, not electrical problem. Maybe overheating but how can you tell if its causing vaper lock?? Submitted by Redroadster.
SOURCE: will a 26 kolher fit a 24 kolher sears tractor
yes might have to change pulley size not much difference just a little more hp
SOURCE: my name is jim. My Sears Craftsman lawn Tractor
Clean the carburetor. The needle and float are stuck closed, passage blocked or a jet plugged with debris. Give it a good cleaning.
