SOURCE: Headlights Not Working, Brights and Turn Signals Work
This is cuased by the multifuntion switch that is located on the steering column. It is the swith with the headlight dimmers on it.
You just need to remove the steering column bezels and replace the multifunction switch.
SOURCE: headlights wont come on and bright lights won't stay on hold bright light switch and blower works
I had the same problem. The solution is simple; the ignition switch needs to be replaced. This is an easy do-it-yourself project. Here are instructions:
http://forums.vwvortex.com/zerothread?id=2532481
Check for a switch on ebay, they are about $15. After 10 years they wear out.
SOURCE: 2002 Yukon XL - No Headlights
Check the headlight fuses in the engine fuse box compartment. Not sure if the lights have relays, but they will be clearly mark in the inside of the top cover for location.
SOURCE: 2002 Saturn, cannot turn off headlights unless I
It sounds like you have a short within your Headlight Switch.....It's kind of difficult to replace, because you have to disable the airbag system....But just take it to a shop an um quit sure they can do it with no problem......You can also try the relay first because its cheaper...But your problem may be your switch itself...Goodluck
