Which operating system ?
Windows Vista 64-bit Driver 7.1 2011-09-20 12.12 MB exe http://www.siliconguide.com/drivers/download/2034/ Windows 7 64-bit Driver 7.1 2011-09-20 12.12 MB exe http://www.siliconguide.com/drivers/download/2034/
SOURCE: compaq presario sr2020nx ethernet adapter issue
Since youre setting up a DSL connection choose Set up broadband connection > PPPoE. You will need the username and password you were given to this account (contact customer service at your ISP for this info). Enter the info and have it remember the password. Click connect. Once Vista finds the connection, it will ask you to choose a network type (Home, Work, or Public). Select the type and enjoy. If the connection fails, recheck your username and password entries.
SOURCE: need to all driver for Compaq presario V3000 AMD64 athlon X2
Hello
Go to this page
http://h10025.www1.hp.com/ewfrf/wc/prodTopCategory?product=1817054&lc=en&dlc=fi&cc=en
and select your model.
After that you can download all drivers for your notebook.
SOURCE: powers up and cpu fan is racing but no boot,
This may be due to a CMOS mother board battery. I know that some tech or expert say that you can still boot without it but my experience is that if the CMOS battery is below 3.4 volts it may or may not post or boot. This battery is about the size of a quarter usually found at Walgreens or Walmart for about 3.00 dollars.
SOURCE: compaq presario sr2020nx will not turn on
change the smpc of your system then try. smpc is a main part of the system its gives the power to the cpu thats way. so change the smps then try if same error occured check the switch & connection etc
ok..bye..........................
