Your circuit lights may be bright or dim according to how your electrical system was set up. It may dim when lights are off and get bright when lights are on. ------------------------------------------------------------------------------------------ Car Diagnostic Tools
i had this happen with my dodge ram 1500. the guy i bought it from put 350 dollar moon lit lights in with leds and they looked impressive but the issue was that they didnt go bright and i could only see 40 feet in front of me and i was sure taping led flashlights would have done me more good that those stupid headlights. then i had the idea of if the brights work and the dims dont then that means no electricity is getting to the dims so i decided to bridge the power from the bright headlight to the dims and it made all four work. now they all work, and only on bright. so im figuring there is a issue with the wiring in the truck. so this is a temporary solution if you really need just plain old lights like i did because i live out in the country
The dim ones are the parklights..........just a few questions first before diagnosing......when you put the switch to dim...you have no lights on ???? is the back lights on, number plate lights ??????..if not, could be the fuse blown for that cicuit......or get this....2 x blown globes...i have had this before......both globes dont work, and i diagnose for 2 hours, and find that I have both globes blown....because 1 globe does 2 circuits, the bright ones could work, but the parklights fail.......
You probably installed the wrong bulbs. Although the bulbs you bought may physically fit into place, they may be wired differently. Go to the auto parts store and look up the proper bulbs for your specific vehicle--don't just buy ones on the shelf that look the same. I have a friend who did that and the bulb he got was designed such that they high and low beams were reversed, so he always had one headlight on high and the other on low!
I finally got mine fixed!! It was the crossover wires between headlights(the wires that run in front of the radiator). One wire was torn into. Spliced them and taped back together. Hope this works for you!! I also used something called wire caps that help hold the spliced wires together. I found this solution on yahoo.com search engine where someone else had suggested this. My only problem was no dim lights, but all the other lights worked fine.
sir once we finish this chat you will be asked to rate the chat. that time please dont forget to give a good rating and review. because many customers dont rate the chat and we experts are left with no credits for providing a solution.
so please dont forget to rate the chat after end of the session. this is just a information to you. always use end session button to end the session.
