How long has it been leaking? If the transmission ran low on fluid for some time, that could lead to big trouble. If it was kept above the add mark at all costs, then a seal or gasket should end your worries.
The location of the leak is important. If it happens to be a front shaft seal that leaks (fluid would be gathered behind the lower inspection plate, on the bottom front of the transmission), then the transmission would have to be pulled out to replace that seal. But other leaks like a pan gasket leak is pretty easy to fix.
SOURCE: Where is the neutral safety switch in a 2002 Jeep
should be part of the prndl switch which is on the trans just behind where the linkage is fastened
SOURCE: 2004 Jeep Wrangler - Clunking Noise when shifting out of Park
It could be lash in the differential which is normal, but it could also be a loose u-joint in the driveshaft. Check the rear driveshaft u-joints.
SOURCE: Dont know were to put in new transmission oil on a 1992 Jeep Wrangler
the plug of the transmission of 1992 jeep is under the transmission case .
SOURCE: 89 Jeep Wrangler. Engine stalls only when I put into gear.
it might be getting to much fuel check the fuel screw
SOURCE: what kind of transmission fluid does a 2001 jeep wrangler need?
Chrysler ATF+4
Testimonial: "quick and clear"
