SOURCE: craftsman snow thrower. headlight stopped working.
The voltage from the alternator is AC, and will increase/decrease with the engine speed, so when checking, run the engine at full throttle. 1/2 of the alternator is not used, the other 1/2 is used to power the light. Also, inspect the light harness plug-in just above or below the starter. Check for being disconnected, burnt, or wiring pinched around the starter mounting area. Lastly, check the bulb with a 12 volt battery, connecting one bulb spade to the + connection of the battery, and the other spade to the - connection.
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
SOURCE: Snow thrower is self propelled. was working fine then stalled
check the bearings in the auger sounds like the froze up and now they need to be replaced (the smoking you saw was from the belts slipping on the pullies)..good luck
SOURCE: Will a snow thrower 42" Mod. no. 486.248392
As long as your deck mounts match up then you should be good to go. You might have to change to a different sized belt though. Other than that everything should be fine.
SOURCE: Will a Craftsman 42" model 486248392 snow thrower
it shooed fit with no problems but first check the crank shaft
to make sure they are the same size that's always ben the
problem trying to switch motors let me no if you need more
assistance
i hope this helps you
bob
