I just got my new modem Dlink DSL-6740U and increased the network speed to 30 Mb. When connected with a cable I get a speed of 31 Mb, but when connected to the wireless I get a speed of 21 Mb. Any solutions/
SOURCE: Dlink Di-514 slow
hi, Need to change teh MTU settings in your router.once you will change it,, it will work
SOURCE: Linksys WRT54G wireless router not compatible with Aztech modem?
Darvin, gotta love your ISP. Never fear......
if it isn't too much of a problem (knowing you have wireless setup done already), then do a factory reset on your router ** remember to copy the WEP Key if you have, or recall the PASS PHRASE so you won't have to reset all wireless devices ** Reset is located on back, you need a ball point pen to reach the reset switch.
Reset process: unplug, take ballpoint pen & insert into reset switch & plug unit back in. Sometimes tricky, but you should notice green light goes to yellow/orange upon resetting.
RESET or NOT - you want the Linksys set for ::
Connection Type - AUTOMATIC (for automatic discovery)
Router IP Address - 192.168.2.1
DCHP - ON, Addresses - 192.168.2.100 and allow 5-50 users
(for security, assign the number of DESKTOP + WIRELESS expected users +1, this way you don't get overrun without knowlege)
Take the cable from Aztech ETHERNET OUT to WAN on Linksys. (usually BLUE) (??) not 100% sure as I have the little silver pocket edition of the same Router. - power cycle (turn both DSL modem & Linksys off for 20 seconds. turn on DSL Modem, wait till it's about as ready as possible, turn on Linksys, should only take 20-30 seconds to power up & recognize.
VERIFY SETTINGS: access router - 192.168.2.1, goto STATUS. you should see IP Addressing, SubNet, DNS1 & DNS2 settings. If you do not, then you have no internet connection.
ALTERNATIVE,
Setup Linksys Router with COnnection Type: PPoE, you will need your ISP assigned ID & Password. Follow all other instructions properly.
If you still have problems, please contact me at 906-495-1707 or via Yahoo IM [email protected] or through this website.
once
SOURCE: how to connect ADSL 2 modem to Wireless Router
just change the ip address in the router and give the proper settings in the router
SOURCE: Cannot connect Belkin F5D8233-4 Router to Mac Laptop
Hi, I had the same problem with my MBP and the best solution I found was:
Dissable the Wlan security and use Mac Address control only for the wireless. This will keep your network secure anyway and you can connect normally.
The only inconvenience is that when you want to connect other computers to your wireless you have to enter its MAC address on the list.
Remember to set the list as Allow.
SOURCE: dlink DIR-615 wireless connection problem
hi. with regards to your concern. there is a possibility that the wireless network adapter driver is corrupted.. try uninstalling the driver for your wireless adapter and reinstall again. once setup is done, view the available wireless connection and connect.. it will ask u the password if there is..then it will connect. if this solution dont work.. try to check your wireless settings, maybe there is a problem on the settings..
