1997 Dodge Dakota Logo
Posted on Feb 09, 2009
Fuse i blew a fuse on saturday when i hooked my battery up wrong and now my dome lights, radio, and my fuel gauges wont work now. can you help me
Anonymous
Level 1:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Feb 09, 2009
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
6
Questions
0
Helped
2312
Points
16
It depends on how long you had the battery hooked up backwards but check for any ground wires/straps from the engine to the frame or body that are burned in to.
2answers
Jeep liberty 2000 No dome lights no spark no gauges no fuel no injector pulse
Check the fuses and if that is not the problem have it scanned by a qualified repair tech.
I’m happy to assist further over the phone at https://www.6ya.com/expert/kim_3202917d7c587455
1helpful
99 Durango- after battery change chg that dome light, radio and tripometer stopped working.
didnjt i see this question a few days ago ,i think they blew a fuse connecting up a secondary power source by the sound of it
2answers
2helpful
3answers
97 Acura 3.5 RL-dome lights, bose stereo won't turn on
Are you sure no fuse was blown? there are more than 1 fuse box (in engine and under dashboard).
Blown fuse
check all fuse and fuseable links, there will be some under the hood also...
Fuseable link are near the battery Hope this works
Fuse Problem
check for a fusable link at the battery + terminal. This will be a piece of wire about 6 inches long, maybe 1/8 In in diameter that is attached to the + terminal of the battery. See if the insulation for this piece of wire is cooked looking. Give 9it a slight tug, does it pull apart? This is the fusable link. it needs to be replaced. By it at the autoparts store. Maybe worthwhile to have a shop install it to get really good connections here.
Note the + terminal of the battery is always slightly larger in diameter than the negative.
Good Luck!
Radio and all dome lights are not working.
interior fuse should be the culprit. Look for the Radio fuse inside (normally 10A red) sometimes labeled CABIN on the fuse layout
I blew a fuse for the front cigarette lighter hookingb up a radio where is the fuse for the lighter
a bad fuse ...keep looking .....otherwise the main acc power/ or ground to all those dash areas has been cut or compromised...retrace your steps backwards
Top Dodge Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Arnie Burke
Arnie Burke
Are you a Dodge Expert? Answer questions, earn points and help others
