1998 Ford Escort Logo
Posted on Feb 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Fuel Filter Where can I locate the fuel filter on a 1998 Ford Escort Wagon?
Anonymous
Level 2:
Sniper:
  • Expert 86 Answers
  • Posted on Feb 07, 2009
Anonymous
Expert
Level 2:
Sniper:
Answers
86
Questions
0
Helped
52428
Points
323
The fuel filter is located against the firewall on the driver's side.
2answers
Does the fuel filter on a 1998 Ford Escort ever need replacing? The owner's service manual doesn't require it.
The fuel filter does need to be changed, approximately every 30,000 miles / 24 months, whichever comes first.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
1998 ford escort has full power , stalled at intersection and now wont start, any ideas
might have a fuel filter problem or a fuel pump problem meaning the filter might be clogged or the fuel pump in the gas tank is not pumping check ur fuse box there is a fuse for the fuel pump in there if it if blown replace and then turn car over again. if its ok then it still could be a fuel pump problem check the fuel filter located by the gas tank under the car or take to a local mechanic if u do not want to do it ur self. fuel filter is easy to change very easy.a fuel pump on most cars the gas tank as to be dropped.
Where is the fuel filter located on the Ford Escort Wagon, 1994?
It's under the hood on the drivers side. mounted to the firewall on the passenger side of the brake booster.
1993 Ford escort wagon replaced fuel pump but still cannot get car to start. turns over, runs as long as you pour gas into carburatorl
the fuel filter may be clogged, and not letting fuel through, if not that check the fuel pressure regulator.when vehicle is turned off, you get a delay in building up sufficiant fuel pressure the next time you try to start it. check fuel filter first. then go from there.
2answers
Location of fuel filter
1998 Ford Escort 2.0L MFI SOHC SPI 4cyl The Fuel Filter is located under hood, driver side, rear engine area, passenger side of brake booster, mounted on firewall.
Hope help with this (remember comment and rated this).
I can not find the fuel filter on my 1998 ford escort, i shave spent all day looking for it, if anyone knows where it is please tell me
The fuel filter is located on the drivers side of the firewall underneath the brake master cylinder. It is easiest to get to it from underneath the car.
17helpful
Where is the fuel filter located on an 98 Escort Zx2?
it is on the firewall under the hood, here is a picture.
1993 ford escort wagon,no electric to injectors
The fuel delivery system uses an electric fuel pump to provide high-pressure fuel to the fuel injectors. The fuel pump is located at the rear of the vehicle, mounted in the fuel tank. It can be accessed by removing the rear seat.
The fuel tubes leading from the fuel tank to the engine are under pressure during vehicle operation. When the engine is turned OFF, the fuel in the fuel tubes remains pressurized for long periods of time to provide quick start-ups. Fuel not used by the fuel injectors during operation is routed back to the fuel tank through the fuel return tube.
The fuel handling components are protected by three fuel filters. A replaceable in-line fuel filter is located inside the engine compartment between the fuel tank and fuel injection supply manifold. A serviceable filter screen is located inside the fuel tank at the fuel pump inlet. A non-serviceable filter screen is incorporated into each fuel injector.
I can get you trouble shooting tips if you want them.
58866017
125387887
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
