Battery went flat now radio dont work no sound or display lights up when side lights on and thats all. all fuses ok and main feed ok radio dont turn on to display radio code to be entered this radio is fitted to range rover and have heard it may be damp causing this problem or is their another problem can anyone help please
SOURCE: ALPINE XQD101550LNF RADIO CASSETTE
ok i found the the code located at address B0h and B2h and it,s repeated again at B4h and B6h but it's reversed ie. 45 67 code would be 67 45
SOURCE: blaupunkt car 300 (D) radio fitted to P registered Vauxhall Astra Merit
you could try holding the power and AS button simultaneously until your hear a dull beep. then it should allow you to enter the code
SOURCE: alpine cda-9857r turns display off but is stiil on.
The display can be blacked out on the 9857r. To toggle between display on and display off hold the function button until it beeps.
SOURCE: looking to enter code in peugeot 406tdi clarion radio PU2184A
CLARION code entry instructions can be found here
Select your model from this long list
http://www.radio-code.co.uk/code-entry-help-Clarion.htm
