It just wont charge,i guess it must be the battery.where can i buy replacement batteries? im from the Philippines, its very hard to find batteris for my oakley thump.
SOURCE: oakley thump pro 05-175
From what I understand you are charging with the USB cable. Did you leave it in at least for 3 hours (the PC also has to be on and not in standy or hibernation mode)? Do the glasses charge with the wall charger?
SOURCE: oakley thump pro glasses wont charge
Check to make sure you are using the USB cable that came with them. Although other cables plug in they create the problem you have. I have had a similar experience.
Make sure you are using the USB cable that came with them. If you use another cable it looks like it should work, but it creates the problem. With the proper cable this may be resolved.
SOURCE: Will charge wont turn on
HI,
Try reseting by holding and pressing the power button of your player for 1min.It should turn on.
stopped playing is the battery dead?
