Need to locate idle solenoid
SOURCE: auto high idle lincoln ranger 8
Had the same problem a couple yrs. ago . Took it to the repair shop turned out to be a diode or transistor type thing less than 50.00 to fix.
SOURCE: My lincoln welder/generator Ranger 8 will not idle
Sounds like your CT or CT board is bad. CT stands for Current Transformer. A CT senses an increase in voltage draw or current, which will trigger the idle solenoid.
SOURCE: Lincoln ranger 8 welder won't run.
by any chance welder has set for a while, or maybe got water in feul , simply drain carb, drain located at bottom of feul bowl, notice if water comes out ,its normal to get a little water thru years of use , try to drtain in container if possible, replace feul filter , and try to clean feul bowl out best you can , give it a try
