Just not sure how to adjust that pressure to get it up to around 9
Many thanks
Pump pressure is adjusted at the pump. There is a nut or screw next to the water inlet that is used to change the discharge pressure. This assumes that your pump is running. Your pressure of 2-3 bars sounds like the pump is not running at all. Put your hand on the motor to determine if it is running. If it is not running then that is the problem you need to diagnose. If it is running then it could be the pump or coupling.
