Sir i want to get the details of philiphs ,nxp tda 9370 ps/n2/3i 1043,9380 ps/n2/3i series uoc ics source code ,or any other methode to copy this type of ic's i have a programer for copying 64 pin dip ic's but nxp has not given the source code so i cant even read the data with out the source code, but some chinese low cost copier can do all this , if you can help me please do afavour
SOURCE: PIN DETAIL IC TDA4867A
The datasheet can be downloaded in PDF format from here:
http://www.datasheetcatalog.org/datasheet/philips/TDA4867.pdf
Dan
SOURCE: can you please give a simple program about defined data types?
http://www.cplusplus.com/doc/tutorial/other_data_types/
Or are you talking about the predefined data types like bool,int,float etC?
SOURCE: NEED TO GET 27 PIN
This IC is available from this link or from electronica but is a bit more expensive.
SOURCE: Samsung crt tv ic tda 9381 mute system not working &No audio . audio ic tda 7297sa
IC fault. Replace the TDA9381. If you wish to get some details; check the site linked here. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
i m facing the same problem what mr.pj_rajesh's is facing...pl guide..
