Polaroid PhotoMax Fun Flash 640 SE Digital Camera Logo
Anonymous Posted on Jan 20, 2013
What are the modifications to download pics from polaroid 640 se camera using windowsxp
I have photomax on my pc, but when I try to download pics from the camera to my pc, it says camera is not connected, checked cables and it is connected. using windows xp
  • Anonymous Mar 27, 2013
    funflash 640 camera does not have a memory card or a orfice to put it in
Anonymous
Level 3:
  • Polaroid Master 32,281 Answers
  • Posted on Jan 20, 2013
Anonymous
Polaroid Master
Level 3:
Answers
32281
Questions
Helped
7913401
Points
102259
ALTERNATE WAY TO TRANSFER PHOTOS AND VIDEOS TO A COMPUTER
If your photos and videos are stored on the memory card, then remove the memory card from the camera and insert it into an USB memory card reader. Connect this USB memory card reader and memory card into the USB port of your working computer. Your computer will see this as an USB Mass Storage Device or an external storage device; you can then open the folder on the memory card and copy the photos and to your computer. Memory card reader is a handy device and is inexpensive. You can copy photos from other cameras and you can also download photos off your memory card to someone else's computer without the need of installing any programs.
5 Related Answers
Anonymous
  • 538 Answers
  • Posted on Oct 22, 2008
SOURCE: I HAVE USED MY POLAROID
hmm..can you supply the version of xp that you are currently using?
Anonymous
  • Posted on May 24, 2008
SOURCE: Photomax and Windows NT?
I need help.
Anonymous
  • 13 Answers
  • Posted on Mar 21, 2009
SOURCE: Using other Camera software with a Poloroid 640 Fun Flash
I have three different digital cameras. I use the scanner and camera wizard to download my pics.
The second option, if you use SD card with your camera, then you can get a USB 2.0 SD Memory Card Reader/Writer.
Anonymous
  • 240 Answers
  • Posted on Jun 19, 2009
SOURCE: Where to get the Photomax CD for PCD 640 Camera
softlookup.com/showdrives.asp?id=6&ch=p
try in this link
Anonymous
  • 33 Answers
  • Posted on Aug 24, 2009
SOURCE: Can I use the Fun! Flash 640 SE camera with Windows XP?
Try the Windows Compatibility Wizard.
Can't download pics from polaroid digital camera to windows xp
Try NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo management program such as Picasa.
Organize edit and share your photos
Polaroid photomax se: how do I turn it on; where does the memory card go; is there an online users manual
There are four buttons on the top of the camera. Looking at the back of the camera and numbering them from left to right as 1,2,3,and 4, the on/off button is number 1. Your camera does not use a memory card...it only uses the internal memory of the camera. If you copy and paste this address into your browser, you can download a copy of the users manual. http://docs.google.com/viewer?a=v&q=cache:3LhHQaK3CyAJ:www.polaroid.com/media/document/fun_640se_qs_rev1.pdf+Polaroid+PhotoMax+Fun+Flash+640SE&hl=en&gl=us&pid=bl&srcid=ADGEESg4CJIWWZoVuHmHEapV5-UBM-MHOqUpM1XIBSxkbZz93C5zd39b0T1KDt48oAACUUR3kCqeOtAzSzhaCVtsvFX8_8ptdYBJBSYRmEAlvwTpsRceIpo37wX7X0uU7ba-wsBvw2lI&sig=AHIEtbRESqAXcLS7AhgXMm-CFzcRt-Abng
When I try to download pics from camera it goes into NOT RESPONDING mode and I can't do anything. It shows up 2 of 8 images and stops and I have to close down everything.
HI,
you have to give a little more info.
On your camera and the computer.
Typically what you are describing is time out. Common if using bluetooth or incompatible software.
Cheers
TeaCii
If you own website, add live support almost free
Real security guard to watch your cctv for $1/day
1helpful
2answers
Windows NT4 and Windows 2000
Windows 2000 A new camera TWAIN driver (version 0.1) compatible with Windows 2000 is now available for download. The new TWAIN driver will allow photo transfer using most image viewing or editing programs that are TWAIN compatible. NOTE: In order for the version 0.1 driver to work correctly, the PhotoMAX software must also be compatible with Windows 2000. The PhotoMAX SE software originally included with the Fun! Flash 640 is not compatible with Windows 2000. If you use your camera and computer with the original PhotoMAX SE software, contact the Polaroid Parts Department for more information about purchasing a PhotoMAX software upgrade. Windows NT4 No TWAIN driver is available for use with Windows NT4.
Can I use a Polaroid digital camera as a web camera?
None of the Polaroid digital cameras listed below can be used as a "web cam." All of these models are designed for taking still images only. DMC/DMC 1e DMC2 Fun! Digital 320 Fun! 620 Fun! Flash 640 Fun! Flash 640 SE Fun! Flash 820 MP3 Digital Camera Olympus C-211Z PDC 300 PDC 640 PDC 640CF PDC 640M PDC 640 Plus PDC 700 PDC 800 PDC 1100 PDC 1300 PDC 1320 PDC 2000/3000 PDC 2300Z
320 x 240 dpi Photo Transfer Problem
Certain computer hardware and software configurations conflict with PhotoMAX or PhotoImpression software. As a result, you may not be able to transfer 320 x 240 dpi photos from your Polaroid Fun! Flash 640 digital damera. This problem does not occur if you use the camera's default resolution of 640 x 480 dpi.
1helpful
2answers
Yes -- with some minor modifications, you should be able use your Fun! Flash 640 SE camera with a computer running Windows XP.
2answers
Can I use the PDC 640 camera with Windows XP?
Yes -- with some minor modifications, you should be able use your PDC 640 camera with a computer running Windows XP.
Top Polaroid Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Tom Shanks
Tom Shanks
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
