What is this it's off the top of my cylinder head off a jf650b kawaski jetski 89 model it's located at top just on other side of spark plug an closest to exhaust
theres no distributor and the firing order for your 3.8 is 1-6-5-4-3-2-the following link shows the coil pack Buick General Motor 3800 V6 Engine Firing Order DIS IDI ignition timing
3.8 Buick Engine Coil Pack Firing Order Spark Plug Wire Location
Which way do the spark plug wires go on & what cylinder is what?
For the Buick V6 231 3.8 liter turbocharged engine:
Answers!
Firing order:
1 - 6 - 5 - 4 - 3 - 2.
Spark plug wire location on coil pack:
Closest to the back of the car, left to right: 1 - 5 - 3.
Closest to the front of the car, left to right: 4 - 2 - 6.
Spark plug wire location on engine:
drivers side, front to back of car: 1 - 3 - 5.
passenger side, front to back of car: 2 - 4 - 6.
.----and this link shows the coil pack to cylinders
. 3 8 Buick Turbo Engine Coil Pack Firing Order Spark Plug Wire Location
A 2001 is only equipped with a 3.4L VIN code "E" V-6 engine. This engine is equipped with a three-coil ignition system with plug wires running from each of the coils to two of the 6 cylinders. There are 3 cylinders on the right bank (the side closest to the driver) and three cylinders on the left bank (the side closest to the radiator).
Bank 1 is where the number one cylinder/spark plug is located. If this is a 4 cylinder engine, number 1 is at the front of the motor and bank 1 is irrelevant and the number 1 sensor would be the one screwed into the exhaust manifold attatched to the cylinder head. If it is a 6 cylinder than number one is on the side closest to the radiator, and at the back of the engine near the exhaust crossover. The number 1 sensor is going to be the one screwed into the exhaust manifold just outside the cylinder head.
New cylinder head bolts coated with a sealant (such as GM 1052080).
Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm).
Using a torque angle meter turn the bolts 90 degrees in the proper
sequence.
Left side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
Spark plugs. Torque the plugs 11 ft. lbs. (15 Nm).
Right side rear cylinder head:
Cylinder head bolt torque sequence-3.4L engine
New cylinder head gasket
Cylinder head on top of the gasket and make certain it is lined up properly with the dowel pins
sequence.
Right side exhaust manifold. Torque the bolts to 12 ft. lbs. (16 Nm).
Spark plug wires
Exhaust crossover pipe. Torque the fastener to 18 ft. lbs. (25 Nm).
Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10
Nm). Using a torque angle meter torque the fastener an additional 30
degrees.
Lower intake manifold. Torque the bolts to 115 inch lbs. (13 Nm).
Upper intake manifold. Torque the bolts to 18 ft. lbs. (25 Nm).
#5 spark plug is the one closest to the back of the engine on passenger side. The location of the #5 spark plug wire on the coil pack is on yhr passenger side closest to the bulkhead between the engine compartment and passenger compartment. Thank you
4.3 v/6 firing order for an S-10 Chevy is 1-6-5-4-3-2, a helpful tip to always locate # 1 spark plug on a v engine.
If you look carefully at the cylinder heads note the very front of each, do you see one sticks out slightly further to the front then the other?
Tghis is the way these engines have to be cast for proper cylinder and timing rotation.
The furthest forward cylinder head is in fact the home of #1 cylinder, it is the first spark plug on that head, which in this case is the right side head.
New cylinder head bolts coated with a sealant (such as GM 1052080). Torque the bolts in the proper sequence (1-8) to 37 ft. lbs. (50 Nm). Using a torque angle meter turn the bolts 90 degrees in the proper sequence.
Cylinder head bolt torque sequence—3.4L engine
Spark plug wires
Valve rocker arms and pushrods. Torque the fastener to 89 inch lbs. (10 Nm). Using a torque angle meter torque the fastener an additional 30 degrees.
Hi Nancycardno,
The spark plug #6 is located on the cylinder head that is closest to the radiator and it is the one closest to the driver-side.Hope this helps,if you need anything else,let me know. Thanks,Chuck
