If I cut the tv on it might cut on or the screan is blue.Sometimes if you put the DVD on for a little while it might cut on.sometimes it cut's off by it self.
try connecting thru an hdmi cable from your dvd player to your tv, check the colors then.. I'd say you have crossed your component cables.. match the connector letters a/b/x? and plug them in one after each other.
Hi, This could be an internal fuse in the tv itself, worth a check if you are confident yourself, make sure you replace it with the exact same type and rating, if it blows then there will be a pretty bad fault somewhere on one of the panels, most likely the power supply.
Please! if you are going to attempt anything yourself be careful, always unplug the TV first before attempting anything and be aware that power can still be held within the TV even when off.
If you are at all unsure please consult your local TV technician.
on what dvd playstation sat box etc? if its scart (red yellow and white) cable then the video (cant remember which colour that is) is dodgy,if its hdmi then u need a whole new cable
rca tv alway have that problem. you could try to clean up all control bottom in control panel or change all.if not. best thing you take down all bottom then only use remote control to operation that tv. good luck!
If you wish to get some details; visit the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Search the site by type in the "BRAND NAME" of your device; (Exclude the model number), in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
dont go to browser screen.wait fo some time.it will load automatically.if you had touchead the lens , dont do it anymore.if you want more sugesstions then fixya!!!
I got this Sony KP-57WS500 57 in TV for FREE from a guy posting it on craigslist because he saw "BLUE SWIRL LINES" also knows as "Retrace Line" on the screen and he went to several repair people and got high repair costs so he was giving it away for free, but i found a guide that tells you how to adjust the tv to make the blue or green or red lines go away, aparantly the line show up because the voltage on the color ray gun tubes that get out of adjustment. Here is the Link to the REPAIR GUIDE. http://www.somelifeblog.com/2007/06/sony-projection-tv-red-line-repair.html
