My heater will blow cold air most of the time, after driving for some time it may or may not get hot. I have found if I do not turn the heat on high and I have it not too much higher then mid heat it tends to go to heat instead of cold more often. Hit and miss..
SOURCE: heater only blows cold air but hoses are hot
Hi!
It
appears we have an Air lock scenario and you will need to perform a
system Bleed.
Park
the vehicle on level ground, when cold remove coolant filler cap,
start engine and leave to idle, turn heater on full and blower to
max. When engine reaches operating temperature watch and listen near
coolant filler, keep clear as gurgling and hopefully a boil over
should occur. Top up with very warm coolant and wait as it may do it
again.
Check
for heat inside vehicle if warm replace coolant cap but keep an eye
on temperature gauge as the ~Air lock may have moved on from heater
matrix/core so proceedure needs to be carried out again from COLD.
If
persistent boil ups/over attention must made in the cylinder head
or
gasket area, or possibly water pump?
Please
press the Blue button to appraise my FREE Efforts, Thank You!
Paul
'W' U.K
SOURCE: heater is blowing but its cold air not hot air 2000 expedition
Make sure the heater core is in the open position by using the shut off valve and turning it to open. next, you may have a malfunction in the direction door the directs the air flow in the dash. a lever may have become lose or separated. may be a bad servo motor not directing the door to move to the heater position. i would start by checking that shut off valve first on the heater core.
SOURCE: ford ka heater blows hot air all the time
Taurus does not use a heater control valve. It runs coolant thru the heater core constantly. You may have a temp blend door actuator problem or a plugged up heater core is also very common. Feel the heater hoses, they should both be very hot, it one is much cooler; you can try to back flush the core.
Your problem is a faulty heater control valve. The design used on these vehicles allows for hot water to flow constantly and compete with the evaporator as there is no blender door. You have to replace the valve and possibly the control head. Meanwhile, you can bypass the valve to have cold air
SOURCE: Why doesn't the heater blow hot air?
If your "Check Engine" or "Service Engine Soon" light is on, you need to have that checked out first.
If not, the next thing you should check is your engine coolant level. (Antifreeze) If the coolant level is low, the engine coolant does not circulate through the heater core and the the heater doesn't work. The coolant level could be low for a number of reasons including a leaky hose, water pump, or head gasket. In any case, if it is found to be low, you need to find out why.
If the coolant level is OK then the thermostat function needs to be checked to make sure that the engine is reaching operating temperature.
If all of the above checks out OK, then the heater control valve and/or the blend air door in the HVAC housing needs to be checked for proper operation. (NOTE: some cars are not equipped with a heater control valve)
NO HEAT ON FLOOR VENTS
As
per your problem mentioned. There are few solved help links to
troubleshoot these problems. Go through the list and Click the link below:----
http://whatisbyme.blogspot.in/2012/05/2000-toyota-avalon-no-heat-on-passenger.html
http://schematicsdiagram.blogspot.in/2012/02/heater-blows-cold.html
http://repairhelpcenter.blogspot.com/2012/01/hot-air-on-drivers-side-vents-only.html
http://technoanswers.blogspot.in/2012/04/1992-toyota-camry-ac-control-light.html
http://technoanswers.blogspot.in/2012/02/no-heatblower-blows-only-cold.html
http://whoisbyme.blogspot.in/2012/06/2009-mercury-grand-marquis-ac-blows.html
http://schematicsdiagram.blogspot.in/2012/04/ac-not-blowing-through-vents-on-2007.html
http://schematicsdiagram.blogspot.in/2012/04/passenger-side-temperature-is-warm-air.html
These
will help.
Thanks.
As
These will help.
Thanks.
